Mp3 300 sport
Mp3 300 sport
Hello all experienced mp3 drivers!
I would need some advice regarding long legs and piaggio mp3. So here it is; I am just over 2 meters tall and wonder what options there are for me to fit better on my scooter. that is, if there is another type of seat, variant of handlebars or covers that allow me to fit better?
Thank you for all the help;)
2015 MP3 500 ie Business
Based on your height alone, the previous generation Honda Africa Twin CRF1000L (2016-2019) would be a better fit IMO. I'm 1m87 and I barely fit the MP3.
The CRF1000L has a base seat height of 870mm, which was a source of complaint for those of smaller stature, and the seat height can be raised to 900mm.
Sounds like this could be the ideal choice for you. Do chose the DCT (dual clutch transmission) version, it is well worth it.
Mp3 300 sport
Mp3 300 sport
Well ive got other bikes but is there any better seats than the orginal ones that will fit the mp3. Im driving instructor and having the mp3 for educational use - stuck with it from this year and next.
Is there anyone who know anyplace where we i can find some kind of blueprint/pdf based schematics of the seating? The tiny book that followed the bike is a joke;)
I would also like to know how to tune it somehow with diffrent weights/tires etc.etc
Highway pegs will be your friends - but no-one is making the support brackets/floorboards at the moment.
@garthhh avatar
@garthhh avatar
Add a pad [40-50mm], which will let you slide back further against the butt stop built into the seat
or
Take the cover off the seat, using a serrated bread knife, trim the butt stop foam so the seat is flatter
Be careful of the sensor
Have a upholstery guy do it if the resulting pucker in the cover is a problem
Not much you can do with the stock suspension, crank up the preload on the rear shocks for passengers
The Bars & controls are fixed and unique enough to complicate taller bars, I haven't seen any after market solutions
@mpfrank avatar
@mpfrank avatar
I am not quite as tall as you, but I have the same problem with the seat. On my MP3 400, I had a custom seat made which really helped, but was expensive.
On my current 2020 MP3 500, I put this on it which, while not as good as the custom seat, made my riding position much more comfortable.
Motorcycle Gel Seat Cushion
Brand: Born Behind Barz
https://tinyurl.com/y3u7e9wr
Piaggio MP3 300 HPE
Piaggio MP3 300 HPE
This is interesting. I'm 168cm (admittedly with a tiny inseam) and I can't flat foot. So there is a sweet spot between the two.
@night_wolf avatar
Waiting
@night_wolf avatar
Waiting
Many people forget there is a difference in how height is measured. I am only 5'7" (170 cm) but have a long inseam @ 32" (81.25 cm). On many bikes I can reach the ground, but the "reach to the bars" can be a stretch. In the process of having the seat on my V85 TT redone to push me forward 2"s. I have a feeling I will have to do the same if I purchase the MP3 500
@garthhh avatar
@garthhh avatar
I'm a 32" inseam, but 73" tall, long torso & arms
I can Flat foot on my MP3[2020] at a stop, I'm #250, so the suspension is compressed some
I added a thin foam pad & a sheepskin cover
The stock foam is firm & could be flattened some to spread the weight away from your tailbone
With my butt against the buttstop my knees are several inches away from the dash, back straight, elbows bent some
The legroom is better than on a Burgman
There is room for you to sit forward
Aprilia Mojito 125
Aprilia Mojito 125
True. I'm 75 inches, have long legs and really fat ass which also steals some space. So I just didn't manage to sit on Burgman (neither of them) and rotate the handlebar. And my first mp3 was bought exactly because it was roomy enough for me.
BTW the Big Beo has less knee space. But better than Burgman or Silver Wing.
@garthhh avatar
@garthhh avatar
I had one of each
To be fair if you take the adjustable butt stop off the burgs you gain some leg room
The burg floorboards have highway position built in, full lazyboy slouch
Aprilia Mojito 125
Aprilia Mojito 125
Yep, when I tried the 650 one, I had to remove the backrest to fit. And regarding the highway position, yep, sometimes I miss that with mp3, but in such case I just slide to passenger's seat for a time.
[ Time: 0.0190s ][ Queries: 4 (0.0098s) ][ live ][ 313 ][ ThingOne ]
