Wed Nov 24, 2021 9:05 am
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 9:05 am linkquote
I have a 1985 motovespa P200E project on the go and wish to rewire the stator plate.
What size/type on wires should I be using and if special (heat resistant etc.) where to buy in UK?
Thanks.
Wed Nov 24, 2021 11:50 am
VNB VSC VBC VSX*2
VNB VSC VBC VSX*2
Wed Nov 24, 2021 11:50 am linkquote
stators are now officially the topic of the day.
Welcome.
Assuming you are talking about the wires from the coils to the junction box? Most of the online vespa shops make kits so you dont have to buy gobs of excees cable. check SIP, etc.
Wed Nov 24, 2021 11:56 am
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 11:56 am linkquote
The only one that I've seen is the SIP one but I'm having trouble ordering on line as I can't put my postcode in on their site.
Was going to try phoning instead.
Haven't found any others that suit on the interweb so any advice on this would be great.
Wed Nov 24, 2021 11:58 am
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 11:58 am linkquote
Just edited the initial post to say rewire not require!
Wed Nov 24, 2021 12:36 pm
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Wed Nov 24, 2021 12:43 pm
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 12:43 pm linkquote
Thanks for the info guys.
Wed Nov 24, 2021 12:50 pm
2007 Stella 225
2007 Stella 225
Wed Nov 24, 2021 12:50 pm linkquote
If your in the US try looking up that scooter thing.
https://www.thatscootershop.com/onlineshop/stator-re-wiring-kit-diy
Wed Nov 24, 2021 1:00 pm
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 1:00 pm linkquote
I'm in the uk but thanks for the heads up.
Wed Nov 24, 2021 1:05 pm
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 1:05 pm linkquote
It appears that SC needs a minimum order amount before they will post to UK so I'm still looking.
Wed Nov 24, 2021 1:32 pm
Rally 200
Rally 200
Wed Nov 24, 2021 1:32 pm linkquote
Hi
Beedspeed rewired my Rally stator some time ago though, this was when Alan Beedham owned the business and they did a cracking job,
Scootronics is the place for stators now but I'm not sure he does Vespas.
Probably not much help, but good luck with it.
Cgt75b
Wed Nov 24, 2021 1:35 pm
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 1:35 pm linkquote
Ta.
I'm happy to rewire it myself, just need to find the resources.
Wed Nov 24, 2021 1:36 pm
Rally 200
Rally 200
Wed Nov 24, 2021 1:36 pm linkquote
Hi
You could always speak to Dave at Wasp-performance in Morecambe he knows his stuff.
Cgt75b
Wed Nov 24, 2021 1:37 pm
Vespa P200E
Vespa P200E
Wed Nov 24, 2021 1:37 pm linkquote
Wed Nov 24, 2021 5:18 pm
79 P200E (Ruby), 62 Allstate (B-62), 2008 Stella (Olive)
Wed Nov 24, 2021 5:18 pm linkquote
I've rewired a couple of stators. I ordered wire (18 gauge) and connectors off Amazon. Links to what I ordered below.
The wire: https://www.amazon.com/gp/product/B011LVF6NW
Connectors: https://www.amazon.com/gp/product/B07FCFH84Q
Liquid Insulation: https://www.amazon.com/gp/product/B000QUOU50
I know you're in the UK, but this is at least a good starting point to find what you need. And a good soldering iron!
Show us pics when you get it all done!
Thu Nov 25, 2021 1:01 am
Vespa P200E
Vespa P200E
Thu Nov 25, 2021 1:01 am linkquote
Awesome.
I keep remembering to take photos only after I've finished doing something so my album is a bit sparse.
I'll try to remember to do before and after
shots.
Thu Nov 25, 2021 6:13 am
2007 Stella 225
2007 Stella 225
Thu Nov 25, 2021 6:13 am linkquote
18AWG wire is a small gauge, how much current is going through the coil wiring? 16 AWG is good for 10 amps.
We'll I was just doing the math if a single wire is carrying 100 watts or about 8 Amps. 18 awg in a length that short should be good for 10 amps also.
Thu Nov 25, 2021 7:05 am
Vespa P200E
Vespa P200E
Thu Nov 25, 2021 7:05 am linkquote
Wires ordered (16g) from UK supplier with sleeves and terminals.
Watch this space for further action!
Thu Nov 25, 2021 8:30 am
bodgemaster
bodgemaster
Thu Nov 25, 2021 8:30 am linkquote
Having rewired a few stators, my feeling is 16 gauge wire is overkill and too bulky. 18g is more than sufficient and much easier to work with.
Thu Nov 25, 2021 8:33 am
Thu Nov 25, 2021 8:33 am linkquote
I agree. 18.
Thu Nov 25, 2021 8:36 am
Vespa P200E
Vespa P200E
Thu Nov 25, 2021 8:36 am linkquote
Blimey, did you sneeze on that mate?
Thu Nov 25, 2021 8:39 am
Thu Nov 25, 2021 8:39 am linkquote
OEM insulation fluid that was used on the original P/PX stator plates. Missing on 99% of "rebuilds" including the video that was posted above.
Fri Nov 26, 2021 8:20 am
Ratty & Reliable 1959 VBA , P125 Engine w/ 166, P200 Primary, 24/24, Sim Pipe
Fri Nov 26, 2021 8:20 am linkquote
Ormsey wrote:
Ta.
I bought 18GA silicone covered high temp multistrand copper "accessory" wire on Amazon, 5 colors in a box, 5 meters of each for about $15.
Fri Nov 26, 2021 8:59 am
Fri Nov 26, 2021 8:59 am linkquote
Stops high voltage arcing. Corona dope. Radio Shack used to sell it.
Tue Nov 30, 2021 3:53 am
Vespa P200E
Vespa P200E
Tue Nov 30, 2021 3:53 am linkquote
How do I add photos?
Tue Nov 30, 2021 11:26 am
Rally 200
Rally 200
Tue Nov 30, 2021 11:26 am linkquote
FAQ: How do I upload a photo?
Tue Nov 30, 2021 4:13 pm
63 Lambretta LI 125 series 3, 71 Sprint Veloce , 2005 Vespa PX150, 1979 P200E
Tue Nov 30, 2021 4:13 pm linkquote
I recently re-wired a stator(5 wire) that had the wiring crumbling and the copper was oxidized. I purchased 5 individual rolls of 20' an 14 gage wiring on of each color(Blue, Black, white, red and green). Each one cost me $8.99 or so.
When it was time to solder the wires I realized the hard way that the wiring was a hair too thick. I ended up having to drill the holes on a couple of the stator pole coils which I did not enjoy doing. The stator works OK but I hate how it turned out. For now I will have this stator as a spare, it works but it looks tacky.
To make things worse I used the wrong type of RTV to isolate the solder points and it did not dried completely after 3 or 4 days so I am not sure if the heat will melt the RTV. Lessons learned...
Tue Nov 30, 2021 4:57 pm
Tue Nov 30, 2021 4:57 pm linkquote
Bummer scooterist.
I just rewired the 3rd or 4th from the list of supplies I posted above. It tested out on the bench so I'm fairly confident it'll be solid.
I've put a few more coats of liquid insulation on it since the pic
  DoubleGood Vespa Design
[ Time: 0.0393s ][ Queries: 7 (0.0181s) ][ Debug on ][ 209 ][ Thing One ]
