@garncarz avatar
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
@garncarz avatar
I am thinking about adding a voltage regulator circuit(s) to my '64 Allstate. I found this schematic:
http://gpzweb.s3-website-us-east-1.amazonaws.com/RegRec/GPZacRegulator.html
In the interest of saving time and money, I am wondering it anyone found an off-theshelf 2 pin 6 volt AC regulator that works well on no-battery scooters?
TIA.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
Here's my favorite. Small, easy to mount, have one on a couple of 6v scoots. Haven't blown a bulb since installing.
https://www.treatland.tv/yamaha-FS1-6V-regulator-p/yamaha-fs1-6v-regulator.htm
@garncarz avatar
@garncarz avatar
I bought one of those, also, to experiment with. So, since there are 3 lighting coils, one for the brake light and 2 in parallel for the horn/headlight/brake light, did you install 2 regulators? Perhaps one at the junction of the 2 yellows and one on the blue wire before the brake switch?
Or......you could jumper the yellows and blue in the terminal box. Then, all three coils are in parallel and you could add just one regulator assuming it could handle the additional current.
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
I'd use a separate regulator for any circuit that's giving you trouble. You can try but I don't think you'll be able to regulate them all via single 30w regulator and a jumper.
'63 GL, '74 PV
'63 GL, '74 PV
Do you have a scooterhelp wiring diagram? Those scans … are hard to make sense of. My 6V bike (GL) may or may not be the same … I was blowing tail lights so I connected a three-wire regulator (ground, unregulated AC in, regulated AC out) on the GL/Sprint/VBB/etc. blue-yellow coil tail/brake/pilot light circuit. That circuit is kind of confusing as the chassis ground is used in an unusual way. A one-wire regulator would only be able to regulate one side of that circuit (e.g. tail light only).
Which bulbs are you blowing?
1968 VBB150
1968 VBB150
Pardon my ignorance, but wouldn't a resistor work?
@gickspeed avatar
@gickspeed avatar
The single best way to deal with this is to increase the wattage of the bulbs.
Agreed. Also, if it calls for a 25w 6v bulb, you can go to, say, a 60 watt 12v one as long as they match up by base, length, etc,,,,
@socalguy avatar
bodgemaster
bodgemaster
@socalguy avatar
In my experience increasing bulb wattage is hit and miss and isn't as reliable as a regulator for solving chronic lighting issues. Higher wattage bulbs will still be prone to dimming at low rpm and blowing at high rpm. I must've gone through at least $50 worth of bulbs on my smallie trying to find a combination of bulbs that didn't blow the tail light, pilot, speedo circuit. A $20 regulator fixed it instantly.
You are right of course. Anyway, these bulbs are not getting any cheaper as time goes by and a reg makes a lot of sense. I think I gave away a couple in the past and now will probably buy a couple again as a fix on my 66 Sprint that is blowing Bulls
@garncarz avatar
@garncarz avatar
So, I fabbed a small aluminum bracket/heatsink and added a pair of 6 VAC clipping voltage regulators. One for the brake light and one for the headlight circuit. WOT gets 6.4 VAC and 6.8 VAC respectively.
https://www.ebay.com/itm/334115845937
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I like it, if I keep my All state AC I'm going this route.
[ Time: 0.0089s ][ Queries: 4 (0.0031s) ][ live ][ 313 ][ ThingOne ]
