@xperimental21 avatar
Super
Super
Do you guys turned the fuel tap off each time the scooter parked? would there be a fuel leak if the tap keep on Open/Reserve position? especially for standard SI carbs
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Yes. Always turn off the tap. Always. The pressure & weight of the fuel is enough to flood the carb while standing still. Even better is best practice to FIRST shut off the tap, RUN the engin e for few seconds 10-30 depending on your who you talk to, then finally KILL the engine. This clears out the unused fuel for an easier start next time.
@chandlerman avatar
Lucky
48 Days Since Last Explosion
Lucky
@chandlerman avatar
I'm going to disagree with GL here...
If your carb needle and float are in good working condition, they should fully seal the fuel flow when the motor is not drawing fuel.
I try to remember to turn off the fuel on my bikes when I park them, but have been known to forget and come back days later. They still start first kick because the needle and float are in good working order and properly seal.
If that's not the case, or you see any leakage/dripping in the carb mouth, or the bike floods if left with the tap on, then you need to replace the float needle for sure, possibly the float, and probably want to polish the needle seat (a bamboo food skewer in a drill is great for this) to ensure a good seal.
The ethanol in gas damages the rubber on older needles, so if you haven't replaced the needle in the past few years, it *will* eventually start to leak as a result.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Valid and good points Chandlerman. I agree that if all is in good working order it should seal just fine. The needle & seat were of course designed for a perfect fuel-tight seal.
I feel that many scooters are in less than ideal condition, and even if the needle/seat seals 95% as good as when new; it still has the potential to leak some. The wear & tear and related (potential) fuel leak will only get worse with time. At some point the seat will need refurbishing on just about every carb. The leakier it is; the more likely the seat needs a polish. CM's advise to use a skewer here is best practice
I'll still stick to my advice to Always turning off the tap, while also acknowledging that lots of people dont do this; and it works out just fine. Lots of ways to peel an elephant
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
GeekLion wrote:
I'll stick to my advice to Always turning off the tap, while also acknowledging that lots of people dont do this; and it works out just fine. Lots of ways to peel an elephant
I'm 100% with you that it's good practice and also that most people's float needle and seats probably leak a little. I'm more pointing out that it not a design flaw that just has to be accepted if you're going to ride vintage.
@seamus26 avatar
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
@seamus26 avatar
I remember the first time I opened the garage and my P had "peed" all the gas out through the exhaust.
I learned a lot that day.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
It wasn't peeing, it was just marking its spot. Razz emoticon
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Good clarification CM! Its not a design flaw (fuel leak), but is an issue that may need to be addressed on these vintage machines. Good knowledge all around Clap emoticon
@seamus26 avatar
@seamus26 avatar
It already had it's own spot; no need to mark it.
Always was a bit of a drama queen.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Not to stereotype, but I think that's just an Italian Thing...
@qascooter avatar
@qascooter avatar
All the old bath mats or throw rugs get relegated as scooter parking.
One morning I opened the garage and the smell of gas permeated the air. The mat was officially an extreme fire hazard.
Ever since I'm diligent on shutting off the fuel tap, and using the q-tip to polish the float seat technique.
@ray8 avatar
@ray8 avatar
Same here. Good way to test the float/needle is to just forget.
I keep forgetting to turn it on too! It's a thing.
My neighbor down the street knows me well. "Why don't you get a newer scooter?"
Tip:
Turn off the fuel with the engine running. If it doesn't die in a minute or so the tap is leaking.
@jackytwoshoes avatar
'13 LML '70 Sprint Veloce
I could never get the float to seal on my Vespa sprint, so forgetting to turn the tap off would eventually lead to an exhaust full of gas.
On my LML, I never turn the tap off and it always starts perfectly. The longer I leave it, the smokier it is on start up however- why is that? Is there fuel sitting around that evaporates whilst the 2 stroke doesn't?
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I actually don't like to run the carb dry with the tap off. Always makes my next start harder. That being said, I assume in this ethanol era it's probably better for the needle to sit dry if it can?
@scooterist avatar
@scooterist avatar
I always completely close my fuel taps. From own experience it appears that maybe my carburetor floats don't work well but I have had tons of problems on all of my scooters when I leave the fuel tap on the open position.
The havoc goes from light to disastrous. I have had fuel coming from the simonize exhapion chamber as if it was a garden hose pouring water, that is how full the expansion chamber was. I also had my exhaust boxes just pouring fuel from the exhaust spiget.
Save yourself some hassle and go for what gives you zero chance of problem and that is closing the fuel tab when you are done and opening it when you are about to ride. my .2c
Unless I'm going into a store for just a moment, I turn it off. It's a habit I have picked up from years of riding bikes and scoots. On some bikes I have owned, I have even gone so far as replacing vacuum petcocks with manual ones. Less stuff to go wrong.
@subetherbass avatar
I don't even have a fuel cock! Just a length of 8mm hose directly from tank to carb!
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
I'll put you down in the "just don't run with a leaky float/needle" column, then.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Mine just sits on reserve, been there for over a year, could be stuck there who knows, if I run out of gas my tank is dry.
[ Time: 0.0183s ][ Queries: 3 (0.0101s) ][ live ][ 313 ][ ThingOne ]
