@swiss1939 avatar
@swiss1939 avatar
I'm normally on the NSM side and don't normally touch the modern bikes, but I've got a neighbor who stops by while I'm out working on my two stroke vintage bikes to chat about his modern vespa. He keeps asking me to help him with his vespa but I keep telling him I have absolutely zero knowledge on anything automatic. But I have been helping him find parts for his bike which he is repairing.
He picked up what I think is a 2018 GTS 300 at one of those government auctions for like 200 bucks and it was in some serious accident. He says he owns a body shop and is a pro at doing the body work and that it is safe despite my warnings that if it was as seriously squished as he says it was.. then its probably not safe to ride even after repairs.
But that is neither here nor there. I'm currently trying to track down an indicator bulb for him cause he says he can't find them anywhere local.
His frame number is ZAPMA39L2J5100150. I'm sure one of you modern pros can point me in the right direction as I already ordered him the wrong bulb (12v/6w baz9s). I now believe it is this 12v/21w bau15s bulb after he brought the correct one he had over to show me (the stamping on the side was unreadable):
https://www.bulbamerica.com/products/osram-7507-py21w-12v-bau15s-original-high-performance-automotive-bulb
Any info would be appreciated!
this is his frame number
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
I have an OEM indicator from a 2020 GTS sitting on my desk and that one has a 12V 10W BA15s bulb.
As far as I know, that should be the same in your neighbors Vespa.
⚠️ Last edited by giallo on UTC; edited 1 time
It's not that one. They are 12V 10W, the base is correct though, 150° offset pins. It's a 5009 bulb:
https://scooterpartsco.com/ricambi/021-vespa/turn-signal-bulb-amber
@swiss1939 avatar
@swiss1939 avatar
Thanks. Then he must have the wrong bulb in his frame cause the one he showed me looked like the 21w bulb I posted.
I'll pass it on!
Thanks for the fast help.
@swiss1939 avatar
@swiss1939 avatar
One last question about this guys scoot. He's also looking for a glove box lock or something, but the glove box door does not have a hole for a lock.
Are these the parts are required for the glove box door locking mechanism?
https://www.sip-scootershop.com/en/product/bracket-glove-box-lock_25242000
https://www.sip-scootershop.com/en/product/lever-piaggio-glove-box-unlocking-seat_PI577861
https://www.sip-scootershop.com/en/product/bolt-piaggio-lever-unlocking-seat-glove-box_PI577400
https://www.sip-scootershop.com/en/product/spring-piaggio-catch-glove-box_PI577005
https://www.sip-scootershop.com/en/product/catch-piaggio-glove-box_PI575607
https://www.sip-scootershop.com/en/product/return-spring-piaggio-lever-unlocking-seat_PI577399
https://www.sip-scootershop.com/en/product/screw-cover-seat-piaggio_PI268596
Apologize but SIP seems to be the only place I can find a parts diagram for this model which I believe they list as a Super/Super Sport/Supertech 300 '19-'20 ZAPMA36-ZAPMA39 model. He seemed to think it was a 2018 for some reason.
Assuming its the same model/parts as in this video from Robot:
or this one:
I'm pretty sure the glovebox hinges and other bits are the same in all GTS variants. If you check the part numbers against other parts lists you can be sure of that.
https://manuals.wotmeworry.org.uk/Vespa/ (go down to the GTS listings)
[ Time: 0.0132s ][ Queries: 4 (0.0030s) ][ live ][ 313 ][ ThingOne ]
