should the woodruft key holds at the end part of the cam's notch/slot?
because when the key was sheared, i found the half part stuck at the middle of the notch/slot (pic below)
because when the key was sheared, i found the half part stuck at the middle of the notch/slot (pic below) |
Posts: 201 Location: no matter where you go, there you are |
xperimental21 wrote: should the woodruft key holds at the end part of the cam's notch/slot? |
markosmarkos wrote: It looks like a flywheel taper you are holding. The woodruff key on the flywheel merely aligns the flywheel onto the taper, for ignition timing. It is the taper that holds the flywheel in place. The woodruff key on the flywheel taper can align anywhere on the groove. If it shears, it may migrate anywhere along that groove. Isn't this part called taper? cmiiw |
xperimental21 wrote: yea i am just worried if my flywheel cam is too long and i use the wrong size Isn't this part called taper? cmiiw |
1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
Posts: 1042 Location: York, PA (the intellectual center of the universe) |
I'd be interested in seeing the condition of your flywheel shaft. Your flywheel interior taper looks to be in pretty bad shape. The woodruff key is simply a position indicator. The friction fit between the shaft and the flywheel is what keeps everything together. The video below show how to lap/fix the situation.
Positive
garncarz wrote: I'd be interested in seeing the condition of your flywheel shaft. Your flywheel interior taper looks to be in pretty bad shape. The woodruff key is simply a position indicator. The friction fit between the shaft and the flywheel is what keeps everything together. The video below show how to lap/fix the situation. I am just curious about the woodruff key position when the flywheel inserted, anyway thanks |
Posts: 1346 Location: Deep in the heart of Texas |
xperimental21 wrote: the crankshaft taper is not smooth anymore, it has many scratches, so i added a piece/small sheet of soda can in hope it will wrap the shaft taper and hold the flywheel. It really works as temporary solution while in emergency situation at least. I am going to get a new crankshaft anyway. I am just curious about the woodruff key position when the flywheel inserted, anyway thanks The woodruff key may or may not fit at the end but it should have the correct width and height to hold the flywheel in one place. |
xperimental21 wrote: the crankshaft taper is not smooth anymore, it has many scratches, so i added a piece/small sheet of soda can in hope it will wrap the shaft taper and hold the flywheel. It really works as temporary solution while in emergency situation at least. I am going to get a new crankshaft anyway. I am just curious about the woodruff key position when the flywheel inserted, anyway thanks |
rowdyc wrote: You're using a soda can? Why not even out the scratches with grinding paste like the video? Using a soda can as a shim does not sound logical. The woodruff key may or may not fit at the end but it should have the correct width and height to hold the flywheel in one place. |
garncarz wrote: The key's location in it's slot is essentially irrelevant. What you need to do is to lap the two mating surfaces. Without doing this, you will never be able to set the timing. No need for a new crank unless there are other issues. |
Posts: 1953 Location: S.Salem, NY |
