My head light bulb has blown out at least 3 times in the past years (sealed factory beam) but when I put the Stella style headlight with halogen bulb it gets super bright when you rev it but it has never blown out. I read 17+ VAC at the headlight connector and I understand that this is unregulated voltage but that is not the issue today .
The problem that I am having right now is that all the sudden all my turn signals, neutral light, tail light , horn and back tail light are lit up with the battery disconnected however everything is very dimmed.
I noticed for a few days that my headlight was very dimmed with the battery disconnected. I let down my guard, I was confused in a way that I saw my rear tail light operating and I assumed that the battery was connected... but you see, I just never ride in traffic without the battery disconnected because I need a good working tail light, brake light, horn and turn signals.
My first thought today was that I swapped out a spare double yellow stator a few days ago when I was Shooting something else so I thought that perhaps the stator that I swapped out was probably too weak. Then I put the original double yellow stator back in and I had the same results (everything works but all the electrical are weak). Then I connected the battery and everything is super bright, specially the headlight.
As you can see I have a list of things going on:
1) headlight very dim without the battery
2) All the electrical systems work with the battery disconnected
What do you guys think?. That never happened to me. At this point I don't think there is anything wrong with my stators.
⚠️ Last edited by scooterist on UTC; edited 2 times
