The first thing until you are sure is to run pre-mix in the gas tank at about 50:1 ( or what is says on the container) this will avoid seizure.
There should be two cables from the twist grip or a split somewhere with the second one going to the oil pump (which will be under a plastic cover?). On the quadrant of the oil pump will be an arrow or line that lines up with a mark on the pump body either at 0 or 100 % open. There will be an adjuster for that cable. It will be obvious whether 0 or 100%
Example below.
When adjusted properly run the scoot for some kms and see if the oil tank level goes down or if there is too much smoke from the exhaust.
No level change or no surplus smoke you'll have to have a closer look at the pump and the tubing.
If you prefer you can disconnect the rubber tube from the engine inlet ( manifold) and run the engine and see if any oil comes out.
If still in trouble feel free to come back or PM.
⚠️ Last edited by waspmike on UTC; edited 2 times
