The first time that I filled up I realized that I was not going to be able to live with the green insert in the fuel tank of my new 2021 Liberty 150S. I realize that it is there for a reason but, since I am not about to fill the scooter with diesel, I decided that I coiuld live without it. I googled around and found this forum but it did not really tell me how to go about performing the removal so I came up with a very simple method. I took a piece of 1/4-20 threaded rod and sandwiched a small washer between two nuts at one end. I
then clamped a pair of vice grips to the rod about a foot up from the washer and nuts. I pushed the rod down through the insert and hooked the washer under the bottom edge of the insert. I then tapped up on the vice grips (used a brass hammer to avoid sparks)
and the insert came right out.
