@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
I have the original piaggio folding rack and the vespa titanium topcase.
I admit they look swell!!!
I got a good deal on it used in mint condition but it was still very expensive. (400 cdn) (here new it is 800-900 from the dealer, about 565 from SIP)
However I am not so happy with the top case, it feels kind of flimsy and scratches very easily.
I also am not so crazy about the locking mechanism and the fact that it does not come off the bike easily.
I am more used to travelling with givi type cases.
I will put the vespa case aside for later or put it up for sale. I can get a decent price for the case alone or with the original rack,
Or it is a big plus of an ad on if -when I ever decide to sell the scooter.
I purchased a small shad case for local riding (sh29) and a large givi topcase (for my long distance summer project)
I can probably find a way to put the givi plate on the folding rack. I have seen a few here in photos. If someone has a good way to attach it in a solid manner I am very interested.
I also saw the givi plate bolted to the non folding luggage rack (photo of FA italia) as well as the givi sr131 and the shad topmaster and am thinking these might be as good or better?
Anybody with experience with a rack that is sturdy and easier to bolt the plate onto?? or am I better to just go ahead and bolt it on the piaggio rack. (use what you have)
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
By using the OEM mount (in your third picture) I was able to use my old Tiger Box (made by Givi anyway)..
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Thank you can you post a photo of the underside of the rack ? please ?
⚠️ Last edited by Spirovision on UTC; edited 1 time
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
I put a Givi case on my GTV, which also came with the standard folding rear rack.
I reversed the position of the springs on the rack, so its "default" position was open. The rack was still liable to bounce when hitting bumps, so I secured it open with some clamps on the bars. Then I installed the Givi mounting plate to the rack, and that was that. It worked great.
I also had it custom painted, and stuck an LXV backrest pad on it.
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
can you post a photo of the underside of the rack Please ?
by they way looks fabulous with the custom paint and back rest !!
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
Thanks!
I no longer have that bike, but I'll see if I can find any photos of when I installed the case.
@lebo avatar
@lebo avatar
I have the GIVI V47 Monokey topcase on my GTS with the folding aluminum rack. The suggested plate adapter is the e-251
https://www.revzilla.com/motorcycle/givi-e251-universal-monokey-top-case-adapter-plate?sku_id=937616
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Hi I have the plate, and the topcase. Do you have a photo of the bottom of the vespa rack where the plate attaches ?
@lebo avatar
@lebo avatar
I do now!
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
I don't have a picture of the underside right now, but all I did was to drill six 4mm holes and then adapt the OEM Triumph Tiger mount to the drilled OEM Vespa rear rack..
I marked in Yellow where I drilled the holes. You can use this system to attach virtually anything you like.. You can also make a plate/jig to fit between the top box and the OEM Vespa rack, so to take bigger top box if you need it...
What ever you use, it will have to be adapted to the existing OEM frame...
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
Lebo wrote:
I do now!
Perfect--I wasn't able to find any photos left of mine.
@crazycarl avatar
@crazycarl avatar
The Vespa Folding rack will accommodate the Givi mounting plate very easily. I had a Givi V46 on my GTS for many years and 30K miles with zero issues. Well built bit of kit.
At Tail of the Dragon, on an 8 day trip.
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Thanks for the photos!!!
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Thanks !!! How did you mount the fuel bottle?
@wbdvt avatar
@wbdvt avatar
Fuel bottle is 4" hose clamps. Here's a pic of mine with a Givi case and base.
@crazycarl avatar
@crazycarl avatar
Just as wbvt shows above, pretty easy to mount under the rack so it's out of the way.
@burt37 avatar
GTS 300 SS BB
@burt37 avatar
GTS 300 SS BB
Also, just for the record, this is the correct way to mount the saddle clamps that hold the top box. In the picture below, they are clearly not, mounted properly. You can also see several scratches on the SS tubing. Perhaps the box is installed and removed on a regular basis, but still...
@lebo avatar
@lebo avatar
You're correct. I'll need to fix that in the spring. Thanks for pointing it out.
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
I have the fuel bottle
Just curious what did you attach the 4'' hose clamp to ?
can you post a photo in the back of the clamps?
@wbdvt avatar
@wbdvt avatar
Wrap it around one of the cross bars. Here's pics from 2 of my scooters. Play around and see what works best for you
This one is threaded betw the 2 crossbars
This one just over one bar and hose clamp screws on bottom
@moto_mark avatar
Vespa 75th Anniversary GTS 300, Vespa 70th Anniversary PX150, Vespa 946, Vespa Rally 200, Vespa PX150, Piaggio Liberty 125
@moto_mark avatar
I have the GIVI SR 131 rack on my GTS and I highly recommend it. I never liked the stock folding rack, useless in my opinion.
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
can you post a photo of the underside of the rack ?? thanks in advance
@abner_bjorn avatar
@abner_bjorn avatar
Here is a Givi Monolock base on a FA Italia rack. Solid as it gets.
@moto_mark avatar
@moto_mark avatar
Here you go...
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
Thank you for the photos !!!!
@lebo avatar
@lebo avatar
I previously said I was going to wait for spring to correct the brackets on my Givi top case mounting plate. It was killing me, I couldn't wait. I removed and relocated the brackets to the correct positions. Can't believe how long it's been improperly mounted! Thanks to Burt for noticing & WBDVT for posting photo.
[ Time: 0.0240s ][ Queries: 4 (0.0171s) ][ live ][ 313 ][ ThingOne ]
