1964 Allstate Cruisaire, 2022 Husqvarna Vitpilen 401, 1972 Suzuki T500J
Posts: 1042 Location: York, PA (the intellectual center of the universe) |
My '64 Allstate has an SI 20/15 installed and came with an extra 20/20. She runs well on the 20/15 and I was wondering if there would be any noticeable improvement gained by rebuilding and installing the 20/20? Or is it such a minor difference that its not worth the time and money? Thoughts? Also, would I need to completely rejet the 20/20?
Twice the area (176mm vs 314mm) in the venturi where the gas and air mix. You will have to rejet some and with a more modern exhaust it will wake the engine up.
bodgemaster
Posts: 7177 Location: So Cal |
The 20/15 is a great little carb but was made strictly for economy. You won't break any speed records, but you'll definitely notice a difference swapping to a 20/20. It'll cost around fifty bucks for a pack of jets and a rebuild kit, and take a maybe couple of hours. Whether it's worth it is up to you.
Jet Eye Master
PX221 MHR, O tuned PX200, PX181, PX125 and some motorbikes
Posts: 4667 Location: London UK |
Posts: 4855 Location: Australa, Mate |
Jack221 wrote: AC140 BE5 MJ110 42/140 to start with |
Air Jet - 140
Main Jet - 110 Idle Jet - 42 Atomizer - BE5 Since I will be opening up the breathing on the front end of the engine, I should likely look for a muffler with less backpressure, correct? Any suggestions for a mildly improved (from stock) street muffler for this type of application? FWIW, I found a OEM jetting chart. |
As I mentioned before, it would help to have a less restrictive exhaust. You are on 8 inch wheels, so you may want to check out this thread: Has anyone solved the box exhaust scraping on 8's? +Solved!
So, I finally got around to disassembling my spare 20/20. Inside is:
Idle jet - 40-130 Air jet- 140 Atomizer - BE3 Main jet - 94 Choke jet - 60 I am going to order the SIP Road 2.0 muffler from Mercato. Considering my Allstate's engine is otherwise 100% stock, could I get a starting jet stack recommendation? Thanks again for all the help. |
bodgemaster
Jack221 wrote: AC140 BE5 MJ110 42/140 to start with I have followed his advice in the past and found it to be very good. Get a couple of different main jets. + and - the 110 starting point. You will definitely play with these a little bit. |
