Sooooo…just got a super nifty set of BGM shocks for the Sprint and wanted to ask the hive mind a dumb question. What's the overall length of the rear. Including silent block and little extension on the top.
Thank you much guys!
Posts: 300 Location: Tempe, Arizona |
Posts: 5102 Location: Australa, Mate |
What model & year of "Sprint"? (They're still making the Sprint)
What size WHEELS does it have? (8", 10") |
Posts: 2563 Location: Siam |
Good questions. That front end looks modernish. Having said that, I've never seen a Sprint with 8" wheels, but I certainly haven't seen much.
Nice cig-butt collection. |
SubEtherBASS wrote: What model & year of "Sprint"? (They're still making the Sprint) What size WHEELS does it have? (8", 10") |
nomadinsiam wrote: Good questions. That front end looks modernish. Having said that, I've never seen a Sprint with 8" wheels, but I certainly haven't seen much. Nice cig-butt collection. I really need to quit smoking…😁 |
Innovator
Posts: 12395 Location: Nashville 129 Days Since Last Explosion |
Innovator
GrandpaNate wrote: Sooooo…just got a super nifty set of BGM shocks for the Sprint and wanted to ask the hive mind a dumb question. What's the overall length of the rear. Including silent block and little extension on the top. Thank you much guys! Lemme know if you need additional measurements.
Posts: 1624 Location: Tucson, AZ |
Unrelated. In what part of Arizona are you? I am located in Tucson. I am about to do a full engine and harness swap on my Sprint Veloce probably this weekend , if I have the chance I will look into it.
⚠️ Last edited by scooterist on UTC; edited 1 time
Innovator
Innovator
nomadinsiam wrote: I think he means top of the rear shock to the center of bolt hole at the bottom. I assumed he was trying to work out what the total length should be to get the correct spacer height given his shock. Either way, he has all his own measurements, plus the total length from me. Anything else he needs to know is simple algebra. |
chandlerman wrote: Wouldn't that just be the length of the shock? I assumed he was trying to work out what the total length should be to get the correct spacer height given his shock. Either way, he has all his own measurements, plus the total length from me. Anything else he needs to know is simple algebra. |
bodgemaster
Posts: 7689 Location: So Cal |
chandlerman wrote: Since no one answered this yet, on my 1976 SprintV, it's right at 18" from the frame to the shock bolt. Lemme know if you need additional measurements. |
scooterist wrote: Unrelated. In what part of Arizona are you? I am located in Tucson. I am about to do a full engine and harness swap on my Sprint Veloce probably this weekend , if I have the chance I will look into it. |
I do apologize for lagging on replying and thanks for the responses! I got em all mounted but will be pulling for adjustment.
I did get a quick blast on the bike after first mounting and already a noticeable improvement. |
Innovator
Innovator
GrandpaNate wrote: I do apologize for lagging on replying and thanks for the responses! I got em all mounted but will be pulling for adjustment. I did get a quick blast on the bike after first mounting and already a noticeable improvement. Upgrading/replacing the shocks makes such a huge difference, but I think that until you've done it, you can't really appreciate how much. I run BGM shocks on my Sprint and GL and they're both really nice. I put a pair of much more expensive Bitubo's on my Stella at one point and don't like them nearly as much. |
chandlerman wrote: No need to apologize. I'm always happy when I can help out around here. Upgrading/replacing the shocks makes such a huge difference, but I think that until you've done it, you can't really appreciate how much. I run BGM shocks on my Sprint and GL and they're both really nice. I put a pair of much more expensive Bitubo's on my Stella at one point and don't like them nearly as much. The only niggle I've found with the BGM (maybe others as well) is the adjustment at the top of the rear shock. As you know with a Sprint ya ain't got much room to do much of anything in there. But then again once it's set, it's set. |
Lambretta GP200, Vespa P200e, Motovespa do Brasil PX200E
Posts: 1218 Location: United States |
