@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Starter is noisy like it's not engaging when cold, it then seems to catch and start.
This does not happen when warmed up.
Any ideas guys,
Your sprag clutch could be on the way out. Happened to me on my Fuoco - eventually the starter would struggle to turn the engine over, and at the end just stalled. A bit of a PITA to replace, but you don't need to take the engine out.
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Thanks for the reply jimc.
Just looking for the part, can anyone point me in right direction
Tia
@maksor avatar
Gilera Fuoco 500ie
@maksor avatar
Gilera Fuoco 500ie
its the flywheel bearing it is in the flywheel and buy the piaggio one i've tried the cheaper versions they don't last
The 400 parts list shows it here, as no.7 'freewheel', it should be similar in the 300. According to scooterpartsco.com, the part number is now 8494905, superseding older part numbers.
https://www.sip-scootershop.com/en/product/starter-segment-piaggio_PI849490
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Well eventually got the sprag clutch delivered, 3 months to come...not good.
What is the torque for the bolts on the flywheel cover, as cannot find anything.
I know the clutch nut torque.
It's the same for all 300 engines, including HPE.
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Excellent Many Thanks
@baboon99 avatar
Piaggio MP3 300ie
@baboon99 avatar
Piaggio MP3 300ie
Just an update on replacing the sprag clutch.
Pretty straight forward job if your handy. done within an hour, longest part was cleaning off the old gasket.
Scoot starting fine and no noise.
Thanks for all the help.
[ Time: 0.0079s ][ Queries: 4 (0.0020s) ][ live ][ 341 ][ ThingOne ]
