Mon, 13 Dec 2021 23:39:59 +0000
vespa sprint
vespa sprint
Mon, 13 Dec 2021 23:39:59 +0000 quote
Hello people,
just got a vespa sprint out of 2014 and having a issue.. It starts well and runs also well. But there are two things.
1 the rpms are not getting high. It stays at a certain rpm and it is not getting up. It also happens when i am not using the centre stand.
2 the rear wheel is not turning.
I have 2 video's that showcases the issue the vespa has.
I hope you guys can help me out with this issue.
Tue, 14 Dec 2021 05:03:38 +0000
GT 2.4
GT 2.4
Tue, 14 Dec 2021 05:03:38 +0000 quote
Sounds like an immobilizer circuit. But it's a 50cc model. Did you recently do any work to it, like put in really heavy weights? Clutch and rear wheel look okay
Tue, 14 Dec 2021 07:09:58 +0000
GTS300 Super HPE, Primavera 125, S 50 4T
Tue, 14 Dec 2021 07:09:58 +0000 quote
1. Variator not moving in when accelerating.
2. Clutch not engaging, stuck, or worn pads.
Disassemble the variator, check the rollers, clean the slide bus.
Remove the clutch bell and check the pads. Replace if needed.
Motor runs, belt looks alright at first sight. Should not be a problem to fix.
Tue, 14 Dec 2021 08:54:29 +0000
vespa sprint
vespa sprint
Tue, 14 Dec 2021 08:54:29 +0000 quote
Thank you guys, ii will have a look on it. I havent done any work on it yet.
Tue, 14 Dec 2021 08:59:46 +0000
Tue, 14 Dec 2021 08:59:46 +0000 quote
the immobilizer system because it sends a signal to the coil when to fire and also limits the spark (Rev Limiter).
https://modernvespa.com/forum/topic8606
Maybe this will help?
Edit:
Vespas in downtown environments tend to get knocked over and pour oil into their air box, so if you have a paper filter your bike might not fire up, but if you have a foam filter you should still be okay to get home/to the shop.
Tue, 14 Dec 2021 12:35:00 +0000
vespa sprint
vespa sprint
Tue, 14 Dec 2021 12:35:00 +0000 quote
Cheked the clutch and rolls today. Has some wear but not that bad.
Tue, 14 Dec 2021 13:42:25 +0000
Contributor
2007 LX 150 (memories)
Contributor
Tue, 14 Dec 2021 13:42:25 +0000 quote
Edit:
If it is a 50cc model, I don't think it has an immobilizer.
Tue, 14 Dec 2021 13:48:24 +0000
Tue, 14 Dec 2021 13:48:24 +0000 quote
With the engine off and the scooter on the center stand, does the rear wheel spin freely? If not, is the rear brake dragging?
Tue, 14 Dec 2021 18:56:36 +0000
2020 primavera 150
2020 primavera 150
Tue, 14 Dec 2021 18:56:36 +0000 quote
Did you check the exhaust?
Tue, 14 Dec 2021 19:05:03 +0000
Piaggio Beverly 300 ie - 2012
Tue, 14 Dec 2021 19:05:03 +0000 quote
Something like in this post of collbain 2000 from Jan 30, 2007 seems very plausible. (in the link waspmike shared)
The engine starts up and idle is perfect but when you turn the throttle then at a certain rpm the engine sound changes and the engine clearly does not ignite at every compression stroke, it runs irregular and clearly misses several compression strokes in between ignitions.
If engine rpm is indeed limited to 2000, then that is probably too low to have the clutch engaged.
So I would start with checking the key and the immobiliser system of your scooter (or better: have it checked because if there is something wrong with it you probably cannot fix it yourself)
Tue, 14 Dec 2021 19:19:25 +0000
Tue, 14 Dec 2021 19:19:25 +0000 quote
That sounds like a virgin immobiliser, before it's been programmed with any keys.
If you have the master (brown) key you can try re-programming it.
Tue, 14 Dec 2021 19:50:05 +0000
vespa sprint
vespa sprint
Tue, 14 Dec 2021 19:50:05 +0000 quote
I got it! I changed the cdi with another one. Thank god the issue is solved. This model has no immobilizer. I am gonna clean everything up and put everything back. Clean it til it's shining and put another picture of it! Thank you all for the help and idea's.
edit: cdi is not shown in the picture (was curious what that is)
  DoubleGood Design
[ Time: 0.0294s ][ Queries: 6 (0.0043s) ][ Debug on ][ 283 ][ Thing Two ]
