@108 avatar
V range 50s
@108 avatar
V range 50s
I'm making up for CM2's lack of reed valve love (hugely appreciative of the persistence with the rotary pad work btw…), I've taken the easy way out and found some old PX cases, welded them up (the guy who did it was half arsed, but beggars can't be choosers…) and ported it to take another vforce4/Malossi 210 kit…
Hope to document the build here…
A little worried actually with the bearing seats… something tells me they might be warped… only time will tell when I install the crank…
Used JB weld on the welding holes left by the hack job…
@chandlerman avatar
Innovator
99 Days Since Last Explosion
Innovator
@chandlerman avatar
Only a 210? No (extra-)long stroke crank?
I'm prepping to take my 210 in the same direction, just haven't quite kicked it off yet, so I'm definitely here for this!
Popcorn emoticon
@108 avatar
V range 50s
@108 avatar
V range 50s
Popcorn emoticon
Ah yes, will be a 60mm crank. Have one on the sidelines ready…
Time to do it CM! Let's get this winter project kicked off!
(But I've still got to rebuild the primary and buy the output shaft….) will be a long journey… last engine was a good 18month piece together…
A bit more filing needed a little over kill on the small side…
My very similar build starts to get interesting around about here:
https://modernvespa.com/forum/post2286504#2286504
I also started with a set of matching case halves that had been butchered by the previous owner. I probably went overboard on the inlet and the crank side edge is a little thin, but it seems to hold tight with a Scooter & Service reed block sealed on top of it. Good advise was to use the 57mm MHR kit, but with a 60mm bell crank and [currently] a 1.0mm base spacer to give 221cc and c.129/186 port timings. It now has Vape variable timing and an MRP 'race' head. Getting the cylinder cowl to fit was a bear with much trimming with a craft knife. Only two upgrades left to do and that's an increase in exhaust duration (~196) and a suitable expansion chamber - any one that allows me to keep the centre stand !!
⚠️ Last edited by swa45 on UTC; edited 1 time
@charlieman22 avatar
Nedminder
Nedminder
Signed up and watching.
Looks like you did a nice job opening up the inlet for the reeds.
@108 avatar
V range 50s
@108 avatar
V range 50s
Thats great!
I was searching for reed malossi 210 threads here, I definitely know of seeing a few via google searches... would be awesome to revisit builds that people worked on.
Trawling through Safis's P build now...
Forgot to mention, will be looking at the new MHR single ring cylinder... will be a Xmas bonus purchase... lol
Thanks! Shouldve taken more care with the rotary tool, but hand finishing it is pretty satisfying...
Didnt want to go for a mirror polish finish though... was referencing some work done back in the UK where the ports were slightly roughed up...
Honestly, need to learn how to weld alu... sick of being a slave to the work done here.
Jet Eye Master
Jet Eye Master
Similar to the best. Set up is everything. There can be about 20 bhp between 221s using all the same parts. Setting up is where the magic happens. I'll chime in as needed if you have a thread for it.
⚠️ Last edited by Jack221 on UTC; edited 1 time
Jet Eye Master
Jet Eye Master
Is this the same 221 we were jetting or another?
@108 avatar
V range 50s
@108 avatar
V range 50s
Different engine mate... so I've basically got a blank canvas.
But again, it might actually be trash cos it seems to be from a written off bike and i havent built it up ever.
I have a 60mm crank and a 68teeth primary (i actually can swap it, but the rest of the christmas tree is stock)
Everything else is i'll need to track down. I dont want to pull from the other engine which runs...
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I know you said you want a street racer, but a 68 tooth primary is going to be low, unless you're looking for a build that's going to get to ~60 MPH really quickly, but not much beyond.
I'd go with a 65 tooth (P200) primary if I were you.
Or put a 3.00 x 11" rim on the back with a 130/70-11 tyre
@108 avatar
V range 50s
@108 avatar
V range 50s
So reviving this thread, been too busy with work to really focus on it.
A lot of the parts have been installed, so basically a retrospect now…
LOOOOOONG STORY SHORT… the cases were trash… the welder warped a few of the bolt holes around the stator… and worse of all, one of the cylinder studs…
Lesson for CM, weld slow… and stay away from holes you want to keep aligned… lol…
Cases fit together, not the greatest in these holes
@108 avatar
V range 50s
@108 avatar
V range 50s
Some progress photos
Overhauled the primary, found using a clamp works stress free, with less cuss words thrown
Aligning…
Aligning…
Then a case of pressing them in with a thumb
Grinding down the main bearing seal… actually getting it in straight is a bitch… always ends up with wonky spacing between the seal and the bearing
Pressed the bearing and seal in cold this time… works, but actually prefer heating the cases up
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Or just keep the motor assembled while you do it! Razz emoticon
@108 avatar
V range 50s
@108 avatar
V range 50s
You can't make it too easy for yourself. Have to add some levels of difficulty…
@scootermarc69 avatar
I think best practice is to machine a round stock to run between the bearing journals that keeps them square.
@108 avatar
V range 50s
@108 avatar
V range 50s
That's definitely a good idea,
Maybe something similar for the cylinder bolts? Or maybe just use an old cylinder bolted down?
@108 avatar
V range 50s
@108 avatar
V range 50s
More photos
Ended up with the gearing the other folks recommended. 55-40-37-36…
Upgraded to a bearing clutch pressure plate… engine is much quieter now when you pull the lever
Not the cheapest part… bit the bullet after thinking about it for about a year and lots of SIP out of stock issues
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I have a different (earlier?) version of that clutch plate and have really liked it. I've had mine for at least five years now in my hotrod LML motor pressing on a BGM Superstrong clutch without issues. Well, clutch plate issues, anyway.
One of the Aussies had one (Ginch, maybe) and had a bad experience with his, though I forget the details.
@108 avatar
V range 50s
@108 avatar
V range 50s
Looks like it might explode, it's a bit thin in some areas… but wonder what the problem could have been
GS160
GS160
I had the (an?) eralier version of bearing pressure plate but when I changed to the Cosa clutch nut it didn't work.
@108 avatar
V range 50s
@108 avatar
V range 50s
I know there were a few problems with fit with a lot of these bearing pressure plates.
Having a taller nut, and then not having it fit is a pita…
@108 avatar
V range 50s
@108 avatar
V range 50s
Last bits of the engine
The fun (not) of cutting out gaskets…
Leak down test… after half a dozen failed attempts over 2 days… using sealant sparingly is your best friend…
Super tight this time, 12hours, needle didn't even move. Most of my leaks were around the reed manifold and exhaust stub
Leak down test… after half a dozen failed attempts over 2 days… using sealant sparingly is your best friend… Super tight this time, 12hours, needle didn't even move. Most of my leaks were around the reed manifold and exhaust stub
@ginch avatar
@ginch avatar
Looking good 108. are they the same cases? How did you get around the warping?
Yes I had a different version of the pressure plate, it had a stub attached that took the place of the push rod. I think there was no allowance for lateral movement, also perhaps not enough lubrication for extended long higher speed runs? Not sure about the last bit. Destroyed the plate and the clutch.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I have the one with the push rod/top hat integrated into it. I think that if your clutch cover and your crankshaft/clutch were even slightly off center from the cover, that could destroy it.
I don't think lubrication is an issue, though.
@108 avatar
V range 50s
@108 avatar
V range 50s
Different cases, had to give up on the welded cases… this one is the old old v1 Malossi cases (seems like piaggio rejects) from SIP. These are epoxy-ed up on the transfer front…
Epoxy works, just have to keep in mind that it needs anchoring in the metal, it's not actually that hard, and it doesn't stick to anything… (which means you can't layer it…)
Using painters tape to create "molds" for the epoxy to sit in, is one of the best tips I learnt.
I've put the welded cases to one side… hopefully one day I can find someone to machine the surfaces and holes so they fit properly again…
Never seen the pressure plate and actuation arm in one piece… doesn't sound very forgiving with the tolerances between parts…
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
It looks like the single-piece version has been replaced in favor of a two-piece, which makes sense for all the reasons discussed above. I just got lucky that mine has worked without issue, I guess.
@108 avatar
V range 50s
@108 avatar
V range 50s
Have a picture of it?
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
This is more-or-less it:
@108 avatar
V range 50s
@108 avatar
V range 50s
More pics
The welded cases come out
Setting the timing marks… aiming 25deg, granted I'm not revving super high most of the time…
Back together… time to sort out the speedo and other bits and bobs
@orwell84 avatar
@orwell84 avatar
You may have mentioned it, but what reed kit are you using?
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Looks like a VForce4 in the picture above.
@108 avatar
V range 50s
@108 avatar
V range 50s
Yeah like CM mentioned, it's a vforce4, on a mrp manifold. With a polini pwk28 carb…
If I could choose again, I'd probably get something else. The vforce reeds seem a little stiff and power kicks in a little late…
All up and running…
All up and running…
parallelogramerist
parallelogramerist
So why is the kickstart lever flipped over?
@108 avatar
V range 50s
@108 avatar
V range 50s
It isn't… angle of the photo?
Nedminder
Nedminder
Hey - 108!
just catching up.
Build looks great.
Not sure it's the reeds creating the lag in it taking off?
Perhaps recap your jetting and remind me about the exhaust you chose?
BTW - I have the clutch with ball bearings that exploded on Ginch.
I've got about 3K - or 4K miles on it now.
I bought the same one you are using as well - but when time came to do this build - I inspected my existing older style - and it seemed fine - so I kept it.
Has been trouble free (knock on wood), and performed really nicely for me.
Ginch - how many miles where on yours when it exploded?
Maybe it was just a defective one?
108 - give us some more details on how it's running.
When do you feel it kick in.
Share a little video from your phone if you can - to let us hear it - if you want some input on tuning.
-CM
@ginch avatar
@ginch avatar
108 wrote:
The vforce reeds seem a little stiff and power kicks in a little late...
I bought a V force copy from Aliexpress (Vforce 3 I think?) and they are quite different stiffness. Not sure which is firmer but can have a look if you're interested.
Maybe, but I feel like Chandlerman was right and it really needed to be perfectly central.
@108 avatar
V range 50s
@108 avatar
V range 50s
-CM
Hey CM2!
Yeah just a reminder, it's a scooter & service newline exhaust, with a polini pwk28, with 45pilot, jjk 2nd clip from top, 142 main jet.
Spent a good day just riding around to dial in the air-mix screw, just to make sure the pilot jet and idle were right…
Was in between 42 and 45… 45 was just more stable at stop lights and idle
Glad you chimed in! Would love to do a video of the riding… but I'm trying to find a decent way of recording the riding with the phone without putting it in a pocket and having blank screen footage… I've tried the MRP phone adaptor… works terrible with the PX headset… any ideas?
Nedminder
Nedminder
you assumed I read back that far?
Makes sense tho now that I better understand what the issue was.
At some point - I should probably replace it with the newer one I bought.
I think the reason I skipped it was; I had heated and bent the rod that comes out of the clutch cover that the cable goest though and pulls on (so it was perpendicular to the cable when adjusted). I also have an adapter that moves my clutch cover out 5mm. All that different geometry would have to be accounted for again if I changed over to the newer version I think.
@108 avatar
V range 50s
@108 avatar
V range 50s
Ah also forgot to post this (for anyone who might be interested, lol):
The polini is quite different to a keihin 28… the polini seems to have improved on a lot of the fuel delivery issues (a lot highlighted in GSF forums).
Polini has wider fuel banjo (but the hose angle is still too high), holes around the float needle (in the carb itself) has been enlarged and has 4 holes instead of 2 to minimise the chance of the needle getting stuck.
So seems pretty good all round.
Keihin, the hole is around 3mm
The polini, hole is around 4.5mm
[ Time: 0.0114s ][ Queries: 4 (0.0032s) ][ live ][ 341 ][ ThingOne ]
