Just installed the Malossi 183cc kit in my 2016 Sprint. Everything went smoothly and the bike started up just fine without the Forcemaster after reinstalling the engine.
I'm in the process of setting up the Forcemaster now, and I have a couple of questions:
1. There are 4 maps preloaded into the unit, but there are 2 sets of numbers. The ones on the outside of the box do not match the ones that are visible underneath the outer case. Which numbers are used to set the map? I also have the Malossi exhaust installed.
2. Where does the Forcemaster get its power? I have connected the ground, TPS, and fuel injector wires. There is a blue wire that is not connected to anything according to the instructions. Does this sound correct? Why is the wire there?
I am having trouble getting the box to power up. My immobilizer has been acting up lately and sometimes I have to fiddle with the key quite a bit to start the bike. Could that be why the Forcemaster is not powered?
3. How does the Forcemaster increase the RPM limits when it appears to have no connection to the ECU or ignition coil? Am I missing something?
Thanks for any help you can offer!
Josh
