125 gt
125 gt
Hello
Can someone explain what is this and what is the purpose of it?
@spacedog avatar
2005 GT200L: (-Jiffy5-) 2013 GTV300ie: (-RBBaron-) 2021 GTS 300 hpe
@spacedog avatar
Fuel supply with a vacuum controlled diaphragm.
Is petcock censored?
125 gt
125 gt
Does it need to be serviced/replaced?
@spacedog avatar
@spacedog avatar
Yes, I think it worth checking out every couple years. A bad diaphragm means too much fuel, while a clogged screen means not enough, but the vacuum line has to be good or it won't work too. Cheap part to change out.
125 gt
125 gt
I'll buy it now
@attila avatar
@attila avatar
Consider eliminating also the rust you see on other components.
125 gt
125 gt
Thanks Attila
One thing at the time.
The exhaust will definitely need to be replaced.
@madison_sully avatar
Antoniokra82 wrote:
Thanks Attila
As long as there aren't any holes in it, I'd just paint the exhaust.
After a good wire brushing....
@spirovision avatar
GTS super 300
@spirovision avatar
GTS super 300
empty the gas tank completely before changing the petcock.
(just sayin )
@stickyfrog avatar
Moderatus Rana
MP3 250 and 2 MP3 500s
Moderatus Rana
@stickyfrog avatar
It always amazes me how many components, fasteners and switches corrode so quickly on Piaggio scooters.
GT 2.4
GT 2.4
Antoniokra82 wrote:
I'll buy it now
They're about $10-12. Better aftermarket ones aren't much more. Cheaper aftermarket ones aren't much worse.
[ Time: 0.0111s ][ Queries: 4 (0.0032s) ][ live ][ 313 ][ ThingOne ]
