Hey, I want to use a sealed front bearing rather than the felt seal, and my GL hub is poor after market. I have a spare Rally fork and hub, all piagio original. Question is, the rally uses a circlip to hold the bearing in and the axle has 4mm clear of the bearing. The GL has no circlip, the axle sits tight against the bearing.
So what's the correct process? Doesn't seem right not to hold the bearing in.
Who has done this before?
Tx
David
