Hello!
Just wanted to introduce myself as I recently joined the forum. Recently I finished "restoring" a 1971 Honda CB175 and now I'm moving into modern Vespas! So I've got some general knowledge of small-ish engines which is helping already.
The past couple days I picked up two Vespa ET2s, one 2004 and one 2005. Both in rough shape, either running, prior owner of course said they were running before they were stored about 10 years ago. Already running into little things that don't really add up from that but that's how it goes. Either way I'm super excited.
Already I've been searching this forum and getting a ton of useful information, also been watching hours of the Vespa Motorsport youtube channel, it's so amazing!
So I'm starting with the 2005 as supposedly it needed the least but I've slowly learning it's actually needing a lot more attention than expected. Right now I'm working on replacing the throttle cables. The splitter is cracked/chipped and not functioning and the cables seem to bind in their housing so while they probably just need some lube, I figured new cables would help overall and I can re-use the old ones on the 2004.
The carb is in good shape but the electronic choke seems to be broken. The piece the needle that fits in the carb is no longer there, and the brass cylinder piece that surrounds the needle seems to be imbedded in the carb. Maybe I'm missing something but I doubt there should be a brass cylinder with a small hole in the carb where the electronic choke fits. If anyone knows if that sounds wrong and that piece should come out, please let me know!
The fuel valve was interesting to me, surprised it uses a vacuum instead of a on/off/reserve switch like on my motorcycle. When trying to replace the fuel and vacuum lines, the fuel tap/valve literally broke and fuel starting running out. Luckily had a bucket ready. Was planning on getting the old fuel out anyways so that just expedited the process. Ordered a couple new taps for both just in case.
Electrics are pretty good, electric start works, blinks and brake light works but headlight and horn doesn't. Good spark from the spark plug. Compression is a little low at 90 but I'm hoping to not have to remove the engine and fits new rings/hone but I figure that might be an option down the road.
Prior owner painted the 2005 pink, while it is blue underneath. The spray paint is slowly chipping off and sort of protected the blue underneath. Hoping to get off the pink as soon as it's up and running. I have all the plastics which are in great shape, but just a little pink.
So that's where I'm at right now. I'll be searching the forums for 99.9% of my questions but may need some assistance here and there.
