Ok hive mind, gots a question fer ya….
P200 engine in my Sprint mounted a Malossi 210 MHR kit with a 30mm Delly with Malossi reed block, Mazzucchelli 60 mm full circle crank, stock P ignition, and slightly lightened flywheel (old school)
55 pilot
138 main
262 atomizer
70 choke jet
X13 needle clip on top location
Revs good enough in 1st & 2nd but falls flat on its face in 3rd and will almost die. If you try to hold mid range constant throttle it also wants to die.
Gettin a tad irritated…..
HELP!!!!
