oxymoron wrote:
Rode to work with no issue today, but then the temperature dropped and it started lightly snowing.
I just went to leave my job for the 5 mile drive home and I can't turn the key.
It took me a minute to even get the key into the ignition, but even after it was in, the whole mechanism won't turn.
Is this common? and How to fix? Get a can of De-icer?
I've ridden through more than a dozen winters with snow and freezing temps and never had an issue like you describe. I've had my car freeze up like that due to moisture in things, but never my GTS250. And I would leave it all day outside my office in rain, snow, and freezing temps.
All I can suggest is to warm it up somewhere, and then hope whatever moisture is there evaporates. As far as moisture getting in, I've seen water inside after using a high pressure washer. I don't wash my scooter in the winter for that reason. Or at least if I do only when the temperature is going to be warm for awhile.
Good luck finding an answer.
