I'm the reg owner. I lost my keys. Do I have any other options other than $800 one from the Scooter mechanic. He said I need the Malossi Racing CDI and then He has to take it apart and install new ignition.
I freak out every time I temporarily (so far) loose my key. I only got the one regular one and the "brown" one. I wish they would have provided two keys from new.
You can buy new key blanks and have them made to match your existing keys, and then you do through a strange little tap dance to reprogram all of them. Just lock away the brownish red key and don't use it.
With the Malossi CDI, you can use the $22 lock set. It's going to be cheaper to do that than to flash the cdi and install a red/blue key set. Parts right at $200. 1.5 hours, more or less. And you have an extra tumbler. if you flash the cdi, you have more labor and down time, even if the tech can leave the bike open on his lift for a week.
By doing it this way, it's a simple on the lift, R&R the CDI and tumbler, off the lift, repair.
All Content Copyright 2005-2024 by Modern Vespa. All Rights Reserved.
