I'm surprised - I thought you needed to run the ABS pump with a Piaggio computer to get the lever feel correct. I wonder if there's a difference in how clean the fluid is between the two methods. (Sounds like lever feel doesn't change so long as you ensure you don't let air in at the handlebars.)
