im in Delaware and have a 2008 LX50 that i recently picked up. the PO had electrical issue and melted some wire behind leg shield. i replaced wiring harness off another parted out LX50 that i had and everything connected without issue. Scooter runs great, BUT i have a wiring gremlin. blinkers/signal lights do NOT work. when i put headlamp on low beam the left blinker lights up, but does not blink. the right (curbside) blinker does not work or is getting power.
i checked all wiring and connections and there is no visible issue. since the wiring harness was melted when i got it, i suspect it may be something is the CDI....but before i plunk down good hard earned money on a CDI that is not returnable, i wanted to see if anyone else had this issue.
Help???
