Hello,
I've got a couple ET2s that are missing the Dellorto brass intake baffle/screen or restrictor plate that sits in between the carburetor and air intake. The Dellorto PHVA carb I have is the stock 12mm but I believe the 17.5mm one also uses the same baffle.
I hope a few of you have removed this as you've added cylinder kits or exhausts, so maybe you have one laying around?
Attached photo of what it looks like.
Any help would be appreciated. I'm located in Washington, DC.
Thank you!
Dellorto PHVA Brass Intake Baffle
