Vespa LX 50
Vespa LX 50
Hello
I just found this great site, and already found loads of useful information here, so I quickly registered.
I have problem with my daughters Vespa LX 50 2T. She accidentally broke her key one day with one piece stuck in the seat lock. After much fiddling I managed to unlock the seat using the other half of the key and then managed to push the stuck piece out.
With this piece I then put it in the ignition lock so I could unlock the scooter and drive it home.
As I could also open the glovebox I just ordered two new cylinders with keys and I then replaced both cylinder which was pretty easy.
All seemed fine and I was very proud of myself until I realized the now the glovebox won't open.
Reading here in the forums I found that there was some alignment of the glovebox mechanism that I should have done when I put on the back with the glovebox. But now it is too late.
I understood that there are some instructions on how to open the glovebox even in this case but it is not shared publicly which make sense.
I would however be grateful if someone would PM these instructions to me.
Thanks and best regards
@greasy125 avatar
@greasy125 avatar
there is a metal lever that the glove box catches on and also serves to open the assembly. more than likely you did not align it behind the ignition piece.
if you haven't received a PM feel free to contact me and I'll walk you through it.
[ Time: 0.0077s ][ Queries: 3 (0.0014s) ][ live ][ 339 ][ ThingOne ]
