@davids_allstate avatar
'61 Allstate / Vespa VNA with a '69 veloce 150
It seems that the vibration of my rides have caused a crack in the leg-shield where the brace ends.
Has this happened on your scoots? What have you done to fix/prevent it?
Here are some pics of the damage and Mr. Knightley saying "Hello"
@jackytwoshoes avatar
'13 LML '70 Sprint Veloce
Check your steering stops- sometimes that crack begins because the handlebars can touch the leg shield
@gickspeed avatar
@gickspeed avatar
Have it TIG welded.
@ph0ngvu avatar
Vespa
@ph0ngvu avatar
Vespa
My handlebar has the similar ~1" crack at the same position. It happened due to a slight hit to the side of the legshield. I have to put on the legshield trim to stop it from cracking any further.
@orwell84 avatar
@orwell84 avatar
I would have it welded. MIG, TIG or oxy-acetylene would work. Preferably someone is works with thinner metals.
@subetherbass avatar
As mentioned, it happens when scoot has been dropped & cowl bent, then straightened, which caused a weak point , that eventually cracks
@greasy125 avatar
@greasy125 avatar
looks like a poor previous repair rearing its ugly head.
non-intrusive you could hit it from the back and see the extent of the damage.
drilling a hole where the crack seems to terminate should stave off further damage.
but you have a decision to make and this is a real choose your own adventure.
fifteen ways to eat a pickle, but it's still gonna be sour.
@qascooter avatar
@qascooter avatar
on my 62 Allstate I drilled, welded, repainted the area, then put aluminum trim around the legshield. I figure the trim will help stiffen it up, but who knows. So far so good.
Good luck!
@scootermarc69 avatar
I found out the hard way why the legsheid always cracks right there and only on the right side. Came out of the bank and the scooter started first kick so I thought I'd make a show of it for the pretty young lady who had just exited the tanning salon that shares the parking lot. Gave it a handful of throttle as I dropped the clutch and lifted the front wheel a touch as I rode it off the center stand. I had realized my mistake before the tire hit the asphalt and I did a nice Judo roll to the right as that's the way the scooter went down with the column locked to the Left. The resulting crease matched at least one if not two previous ones and I knew right then this wasn't the first for this scooter. I took a bow and slinked away.
Related, I once rode from Atascadero to San Jose on back roads only to realize when I got there and the flapper style column lock clicked as I turned the the column all the way to the left that my colunm lock had been in the lock position the whole time. Facepalm emoticon
Edit b/c I always get left and right mixed up
⚠️ Last edited by scootermarc69 on UTC; edited 5 times
@geeklion avatar
The Dude
The Dude
@geeklion avatar
scootermarc69 wrote:
I found out the hard way why the legsheid always cracks right there and only on the left side. Came out of the bank and the scooter started first kick so I thought I'd make a show of it for the pretty young lady who had just exited the tanning salon that shares the parking lot. Gave it a handful of throttle as I dropped the clutch and lifted the front wheel a touch as I rode it off the center stand. I had realized my mistake before the tire hit the asphalt and I did a nice Judo roll to the left as that's the way the scooter went down with the column locked to the right. The resulting crease matched at least one if not two previous ones and I knew I right then this wasn't the first for this scooter. I took a bow and slinked away.
Related, I once rode From Atascadero to sea Jose on back roads only to realize when I got the and the flapper style column lock clicked as I turned the the column all the way to the right that my colunm lock had been in the lock position the whole time. Facepalm emoticon
Showing off for the crowd always leads to cracks in the facade. Hope you're ego wasn't too cracked up as well. I bet you made an impression, although perhaps not the one you intended Good on ya for taking a dip, taking a bow; and scooting off I'm sure as quick as possible.. Clap emoticon Clap emoticon Clap emoticon
I found out the hard way ......
Well at least your heart was in the right place as well as your VespaPride. But sadly looks like it was only your EYES working good in your dang head this time!
... I took a bow and slinked away.
and anyways, I'm pretty sure it is 'slunk' or maybe 'slunked'? Headache emoticon
Please, It took me 6 tries to get my lefts and rights sorted. I only gets so good
I had to pull out the pictures from 2009. I didn't believe it's was from previous damage; but you are right- you can see the crack in the exact same spot!
Crap! You're right, too, any fix is going to be a sour pickle!
Honestly, he was a little rust bucket when I got him... I thought I did better cleaning and repairing him.
Like me, we're both showing our age...
@chandlerman avatar
Lucky
153 Days Since Last Explosion
Lucky
@chandlerman avatar
I just dealt with this exact issue on my VBB. my solution was maybe more aggressive than most, but the results should be worth it.
Holy Smokes, dude! Wha? emoticon
I just looked at your yuetube channel too. Clap emoticon
I wanna be like you when I grow up!
Tools and know-how! I have neither!
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Thanks! I don't know about know-how, but I do have a few tools at this point.
I've slacked pretty hard on any video of the VBB rebuild. Nothing that interesting yet, unless you find videos of me cursing, scraping, hammering, and sanding to be interesting, in which case you need help, not more videos from me.
If you want the even more detailed blow-by-blow, I did a thread on it, of course. It covers a lot more than the videos: 63 GL: First Bodywork adventure
[ Time: 0.0169s ][ Queries: 4 (0.0045s) ][ live ][ 313 ][ ThingOne ]
