So, the time came to mate the two halves of my stock 180SS motor together. I laid out the bolts etc. ready to put in place when it came together, attached the kickstart lever to the quadrant and gently put the right side over the left side. It slid gently down the studs that are in the LHS case then stopped!
1. I had the kickstart rotated to engage with the engagement gear.
2. The gear change barrel appeared in the appropriate hole, but didn't come out into the clear air.
I fiddled around with the kickstart hoping to free the right case but to no avail.
So, I took it apart again and took the kickstart quadrant out (oh the joy of taking that spring off) and made sure the end of the quadrant fitted the bush it is meant to go into - it does.
So, I refitted the kickstart quadrant and spring, and fitted the kickstart lever and tried again. Alas, no luck.
Am I missing something?
