Hi There,
Thank you in advance for taking a look at my thread, I tried searching the forum for related issues but the search function was buggy.
I have a 2007 Vespa GTS that is ridden on average 4 times per week as my daily driver [10 miles round trip]. It used to be every once in awhile the machine would haver an issue turning over when started, it would crank and then die. The problem subsided for about a year and a half without any meddling on my part. I figured it was bad fuel.
Recently, I find that under acceleration the GTS will sputter and decelerate or at times completely lose power from the motor. The machine itself is still being powered by the battery, though the engine is cut off. Here and there when I approach a stop light and idle waiting for the green, the engine will die. The same goes for when turning over from a cold start. It will fire up, rev and then die. This is all very inconsistent, but it is happening more frequently.
The GTS has 24K miles on it, and from my understanding this model was not affected by the fuel pump recall.
Does anyone have the slightest idea if this is a fuel pump issue or something to do with the relay? Is it a completely unrelated problem? Any help would be greatly appreciated.
Thank you again,
HermosaBeachGuy
