Sun, 13 Feb 2022 07:01:17 +0000
GT200
Joined: Tue, 18 Jan 2022 17:50:02 +0000 Posts: 15 Location: california
GT200
Need some help. Scoot started cutting out every now and then, but now won't restart at all once it cuts out for a few hours.
Symptoms:
1 - When on stand/parked... I start it and 30 seconds later it idles super high and rear wheel goes crazy fast
2 - I can start it now and then and ride it maybe 100ft and it cuts out and I cannot start it again. I have to push it home.
3 - terrible on gas and smells like gas
4 - gas leak/wet hoses coming from gas tap/petcock. I tightened hose clamps, but is still acting the same.
5 - I changed airfilter
I'm getting close to thinking it's a bad petcock. Any ideas?
Sun, 13 Feb 2022 08:54:06 +0000
Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
Joined: Sun, 21 Jan 2018 16:14:34 +0000 Posts: 476 Location: Wales
I would replace the petcock and if the vacuum and fuel lines bit old change them as well.
Sun, 13 Feb 2022 09:41:16 +0000
'07 GTS250ie "Mechanical Squirrel", '66 Honda Benly, '19 Suzuki 250 cafe "Mouse", '77 Jawa 350TS, '42 Henschel PzKw VI Tiger
Joined: Fri, 01 Jul 2011 13:22:16 +0000 Posts: 880 Location: somewhere deep in the back of the garage...Burlington ONT.
I'm not familiar with the carb on these things, but I had very similar problems on a bike a few years back and the issue was a defective float. I'd check the float for damage or deterioration as well as the valve.
Sun, 13 Feb 2022 15:55:38 +0000
GT200
GT200
I'll check the float, thanks. I hope it's nothing major. It was running great all this time Fritz Katzenjammer wrote: I'm not familiar with the carb on these things, but I had very similar problems on a bike a few years back and the issue was a defective float. I'd check the float for damage or deterioration as well as the valve.
Sun, 13 Feb 2022 16:42:38 +0000
Joined: Wed, 29 Jun 2016 14:22:10 +0000 Posts: 1765 Location: Toronto
Wolvernerd wrote: 4 - gas leak/wet hoses coming from gas tap/petcock. I tightened hose clamps, but is still acting the same.
I'd start here, as this is definitely not right. The petcock is vacuum operated, and should block fuel when the engine is not running. It sounds to me like yours has failed and is flooding your bike.
p.s. you posted in wiki section, so your post is probably not getting as much attention as it normally would. Maybe ask a moderator to move it to "general"?
Sun, 13 Feb 2022 21:36:13 +0000
GT200
GT200
Perfect, thank you so much. I will order the petcock and hoses. berto wrote: I'd start here, as this is definitely not right. The petcock is vacuum operated, and should block fuel when the engine is not running. It sound yo me like yours is failed and flooding your bike.
p.s. you posted in wiki section, so post is maybe not getting much attention. Maybe ask a moderator to move it to "general"?
Mon, 21 Feb 2022 03:31:09 +0000
GT200
GT200
OK just did the following and my GT200 is back up and running like a champ.
1. Air filter - it was not too bad, but time for a change
2. Spark plug - the old one was completely burnt out
3. Fuel filter and fuel lines - not in bad shape, but lines were leaky at the petcock
4. Fuel pump - looked pretty warn, worth a change
I am however going to clean out the carburetor, to see if it gets better idle and performance, buy at least it's going steady again. Thank you all for your help!!!
Mon, 21 Feb 2022 06:12:49 +0000
Wolvernerd wrote: OK just did the following and my GT200 is back up and running like a champ.
Great to hear! Well done!
Mon, 21 Feb 2022 22:55:58 +0000
Joined: Wed, 21 Jan 2015 19:49:18 +0000 Posts: 1636 Location: Hamilton/Kirikiriroa, NZ
Awesome - great news.
