So I have a brand new 2021 Sei Giorni, and I am wanting to upgrade both the front and rear brakes and calipers, and possibly master cylinder, and lines.
Does any one have this done what did you use, Brembo, Malossi, more important how much better feel and braking do you notice over the stock set up. I don't mind spending the money as long as it makes an amazing difference.
One other question can you do this yourself? I have heard rumors that when you change them out the ABS light will come on and not function correctly, and the only way to fix that is the dealer with their laptop resetting it ? is that so? If so I would have the work done at my nearest dealership which is 3 hours away.
Any other suggestions would be appreciated, for me, when I hit the brakes I would really like a great feel as to what the tire and brakes are doing in concert, and a huge noticeable difference whereas when you hit the levers its like whoa? if that is even possible.
Norm
