Hi,
In this video from VespaMotorsport
they imply that the lower race must be removed to remove and fit a new fender.
Is that true?
I got a P200 with a mangled front fender so planning to replace it with a "Mudguard SIP EVO II"
Thanks in advance
Never mind. This http://www.vespamaintenance.com/body/forks/index.html
page indicates that the fender can be removed without removing the race
@greasy125 avatar
@greasy125 avatar
it can be done with the dust cover in place (it's actually the dust cover that it hangs up on not the bearing race) it just takes a little fiddling about and contortion but it'll come.
if you're there, have a look at the bearings (both top and bottom) and determine if they need refreshing in that it's an ideal time to do so while it's all apart.
thank you. i definitely will. also hope their not rusty, so I can knock the lock rings loose with a screwdriver and hammer, and I just have to pack the bearings with grease.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
The bearings are pretty cheap, if you have it apart I'd replace with fresh, even if you're not doing anything with the seats.
@chandlerman avatar
Lucky
158 Days Since Last Explosion
Lucky
@chandlerman avatar
I was just about to say this. The races last damn near forever and the bearings are the sacrificial part.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
you guys saved me on that one, so I figured I'd pass it forward
[ Time: 0.0096s ][ Queries: 3 (0.0037s) ][ live ][ 313 ][ ThingOne ]
