'81 Vespa P200e, '85 Vespa PX125e, 1985 T5
Hey all.
Looking into this t5.
Thoughts on what it's worth.
It's all original from what I can tell.
But it's rough. Engine will need a full build as well.
@greasy125 avatar
@greasy125 avatar
any more pics?
on the motor, how do the cases look? pad okay, no cracks, nothing ported or scooterboy'd up?
Well the engine has the original cylinder on it. But not the original 24/24G carb. Seat is gone. Rear light is gone. Cowl rubbers, gone.
I tried locating the engine vin numbers on the stamp plate of the engine swing arm (where the vin numbers should be) and that is blank.
The seller told me that in the documents of the bike's history, there was a work order got engine installation, but nothing more than that. The seller himself doesn't know a thing about the bike. He bought it, hired some guy to strip the Original paint, and the guy who (poorly) stripped it, left the bike to sit for a number of years.
Now the seller wants to unload it.
I attached one more pic.
@safis avatar
@safis avatar
Looks like a T5, probably is, but make sure it has the correct engine that is famous for. Easiest giveaways are the kickstart and the cylinder cowl...
Man. I thought the Kickstarter was installed upside down. Lol.
Has the cylinder shroud.
Has the kick start
Has the original cylinder
Even has the same flywheel as seen in your pic.
But I'm unsure of the cases. Unsure if they have the 5 ports or not.
Could it be possible to put 3 port cases with the 5 port cylinder?
@safis avatar
@safis avatar
No, not possible. Totally different layout. If the cases were replaced it makes sense there's no VIN on them. They came blank from the factory...
My NOS cases...
@greasy125 avatar
@greasy125 avatar
show us a pic of the motor.
that will be the deciding factor.
pic of motor.
@safis avatar
@safis avatar
I'd say 99% it's a T5 motor. Kickstart is PX that's why it sits like this on the T5. You said the carb is wrong, I'm afraid the whole "tub" is wrong, which is also unique to the T5 and an "unobtainium" part nowadays. I've been looking for one (to have on the shelf) for over a year now, but no luck...
@greasy125 avatar
@greasy125 avatar
I'm at 99 of it being a T5 motor
the carb situation isn't the end of the world. it may have the OG box and just not the carb or filter or top. worst case you could always port a stock box to match the T5 inlet, get the right (or a better carb) and filter and what not.
the T5 kickstart quad is a strange beast and only fits T5 or rally style levers. so it looks like the mushed a PX one on there.
so, anyway it's non injection which is fine. how's the frame look under the floor mats and spoiler? how's the speedo and gauge cluster and does all that shit work?
I'd triple check the vin to make sure it's actually T5 and not excel
now onto the million dollar question: how much loot?
parallelogramerist
parallelogramerist
I'm currently a T5 owner, and that looks like a $1000 hot mess to me.
The vin on the frame is a T5. Vnx5t.
The engine is not running. Who knows what's going on there. So I have to tinker a bit to get it going.
I kinda wanted to see considering all this info, what you think is a fair price to pay.
@greasy125 avatar
@greasy125 avatar
Lemme mull it over.
Imma make a blt and think about it…
@greasy125 avatar
@greasy125 avatar
My NOS cases...
perfect example!
@greasy125 avatar
@greasy125 avatar
without getting into an esoteric discussion of what is a T5 worth, we can all agree what is or makes a T5. that being said it is a T5 and it's a roller.
a T5 motor is easy 1K open market, and a bike that's a roller is worth somewhere between 500~1500 depending on what it is. so something like 1~2.5
basically, you're buying 99% of a T5 motor and about 80% of the rest of a T5. but the catch is all the little fiddly bits: the seat is dough, if the instrument panel is waxed there's mas dinero, getting all the *right* bits for the motor, some trim bits and the windshield. you could easily dump 2K into this with just tires, tubes, cables and cosmetic. then addressing the motor. figure a soft parts rebuild at 500
and that's before paint!
I mean, sure you could rattle bomb it for the time being. cruise it around and then decide what you wanna do from there.
the thing that it really boils down to is do you really really want a T5? if so then you're gonna drop the loot.
I'd run the comps and see what you come up with. I've seen them trading hands in the 4~5 range for very nice examples. you'd be MILES ahead if you scooped something even if it was a little tatty in the 3K range than with this as a starting point.
just back of the bar napkin math puts that into that 4 range easy money.
as a benefit, you're in Canada so there's more examples up there than down here.
long ramble cut short, I'd say no more than 2K maybe 22 if it came with the standard "mystery rubber tote full of parts" and tags were set up and they delivered it to me.
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
that's pretty much it ^.
if you want a T5, you will go for it. Down here there are none available unless I get Greasy to part with his, but that ain't gonna happen. I guess Canada had some? Finding T5's in the US is like finding PK's. There are a few but if you want one you can't be choosy... Speaking of PK's, he's got one of those too. Hmmm.
@greasy125 avatar
@greasy125 avatar
John, I'm trying to collect the whole set.
now all I need is a cosa!
but I'll tell you what, I'll trade you my PK straight across for an ETS in blue...
I got your Cosa, it's even a late model 'Mark II'! So it's got your convenient oil level gauge, lovely single cable shifter AND factory aluminum cylinder that needs that odd muff connection w/ a flange - all normally only available in Europe. Wha? emoticon You're in for a treat!
But for you my friend, dead cheep and I mean like the price of a good meal. I prefer downtown. With a few friends of course, but still we're talking CHEEP! You pay the postage please, and sorry, bill of sale only.
Motor is together and runs well take my word, and the rest is mostly complete and in nice sturdy boxes, the way you are used to and likely prefer so there's still a bit of a challenge to keep you properly engaged! Shoot me your shipping address.
@greasy125 avatar
@greasy125 avatar
gahhh.... don't tempt me!
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
you know Saints title will get that thing titled Greasy, do it!
How much to import one from the UK? Cosas, PKs and T5's (the original and classic) a plenty over here. Cosa's go for pennies, pick up a mint 200 for less than 2k, PKs are on the up and T5's 3k sterling upwards. We get plenty of TX200's turning up too from spain. (t5 look alike with p2 engine).
@oopsclunkthud avatar
3:5
do it!
parallelogramerist
parallelogramerist
I have no idea how many T5's are located in the US, but I think there's about 5 different ones that reside up here in Oregon? What I'm curious about is where Rolf's immaculate jet black T5 went to after he passed. His scooter was the shiniest black anything that I've ever seen!
@greasy125 avatar
@greasy125 avatar
oopsclunkthud wrote:
do it!
you are a very bad influence.
(yes I am thinking about it)
@greasy125 avatar
@greasy125 avatar
Rolf's was sick AF all murdered out. such a nice bike. Thom had a really nice one in charcoal/silver that was set up really well. Marcus has that tricked out blue one that's really nice. I think Adrain still has his red one and there may be one or two others kicking around down here.
but stateside I'd put the T5 number at less that 50 if I had to guess.
@greasy125 avatar
@greasy125 avatar
import probably wouldn't be too much of a killer, but getting it titled and on the road legally might require jumping through a bunch of hoops.
TX200? Spain? oh no... I think I hear someone near the vicinity of Houston mobilizing units...
@sdjohn avatar
Johnny Two Tone
Johnny Two Tone
@sdjohn avatar
Saints title for gray market bikes - I've already done that...
@geeklion avatar
The Dude
The Dude
@geeklion avatar
A friend up in Seattle has an electric start T5, italian not spanish, the Fifth one made in series. Its immaculate in red. l
[ Time: 0.0155s ][ Queries: 4 (0.0066s) ][ live ][ 313 ][ ThingOne ]
