Update-
Carefully pulled the jets, cleaned the shit out of them and their home...jets are definetly clean; as well as set right-
As far as the float; I seriously doubt it..not to say it isn't a remote possibility, but I was out riding, and after about 20 miles, it conked out; luckily smile from home-
Carb
So far- here's what's been done-
Replaced vacuum fuel tap, checked before installation and it worked-
New vacuum and fuel lines with proper hose clamps, from dealership.
new 3 way barbed connector-
All connections double checked and right-
Carb pulled, jets pulled and blasted out with carb cleaner- light visible thru holes, put back as they were removed- their slots also blasted out- checked for corrosion; nothing.
Went back a second time to make sure-
Checked accelerator pump; she squirts.
Checked spark plug and connector; strong spark and clean.
Pulled the hose off the air cleaner, no change, so it isn't a dirty box.
The transponder blinker is blinking as it has, same single blink, start up the bike, she shuts off.
I'm boggled at this point-
Been (greatfully) writing back and forth with greasemonkey-
Below is a YouTube link to what's going on. I tried posting it in attachments here but it doesn't seem to want to add it.
https://youtube.com/shorts/xXfZtL0HNo8?feature=share
