chandlerman wrote:
Welcome!
First off, 20+ HP is not plug n' play territory. And doing it on a rotary, even a 187, is a pretty good trick that most people never achieve. 15-18 is a much more realistic goal, especially for a first build.
Now that I've gotten that out of the way, the first thing I'll say is that you're probably going to need a tuned pipe or a big box exhaust like a megadella.
Also, let's talk about some more specific goals. Are you looking for a highway tourer? A stoplight racer? Do you need a wide power band or is something peaky ok? What sort of top speed are you needing?
And, of course, how frequently are you willing to rebuild the motor? Because highly tuned motors need about 10-15x the maintenance of a stock-ish build.
Next, you need to add aluminum to the cases so you can open up the transfers, then get to work on the cylinder and piston with a Dremel. You'll also need to open up the intake, both length and width. The exact timings of the intake, transfers, and exhaust are a bit of math, more than I have time or information for here.
I'ts hard to answer those questions without any scooter experience. I bought it mainly to commute with low fuel consumption, to spare my car that is high on petrol (~12L/100km). Let's say I will use it for commute and occasional B road. I guess a wide power band is always a plus and 70MPH seems plenty to me. I have a Hornet to reach higher speeds.
What rebuilding intervals are we looking here? It will see 2.500-3000km/year and I wouldn't like to rebuild it in the next 20.000km.
The last part is what scares me the most, adding alluminium to the cases is clearly more that I can chew, unless there are clear instructions somewhere.
Christopher_55934 wrote:
If you're trying to get that much power, a reed valve intake from MRP or similar would most likely make it easier.
I would like to keep it rotary.
Thanks for your feedback.
