@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
The fuel gauge on my ET4 reads full all the time . Is the fault with the gauge , the sender unit or maybe a wiring fault ? Any thoughts ?
@greasy125 avatar
@greasy125 avatar
it's most likely the sending unit. there are two versions, well technically three. one is a loose float, those are the earlier ones. the second is a tube with the float in it, these came later and they have two different electrical connections. one is a three prong in a triangle connector and the other later, later one is a rectangular connection.
on the version with the tube the float will occasionally get hung up or stuck. you can try jostling it around to free it, but usually a replacement fixes it.
if it's wiring, more than likely your short is in the headset/handle bar area.
hth
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
I forgot to mention that the fuel warning light on the dash is working ok , does that work from the sender unit too ?
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
Thanks for the help Greasy .
@greasy125 avatar
@greasy125 avatar
did you get it repaired to your satisfaction? if so what was the fix?
[ Time: 0.0104s ][ Queries: 3 (0.0047s) ][ live ][ 343 ][ ThingOne ]
