garwilla wrote:
Thanks, y'all. I checked the coolant, added a bit and will see what that does, but yeah, a coolant flush is probably a good idea.
And, I hear you about air cooled, this is my first water cooled two wheeler...loving it though.
Going back to your first post.
It is a 2020 model and has run 3500 miles. That means it is quite new and has low mileage. There is no reason to expect a major problem.
You have it for some weeks. We are now end of February, so you got it probably early this year. I see you live in Santa Cruz. I expect moderate temperatures maybe 10 to 15°C, but certainly not hot summer temperatures. So there should not be any problem with the cooling capacity.
If you run the scooter at close to its max speed then the engine has to deliver close to its maximum power and needs maximum cooling. If the engine temperature gauge then goes up and the warning light goes on then it means there is not enough cooling capacity.
Or there is not enough water flow, meaning there is a problem with the water pump or the thermostat does not open fully or the water flow through the radiator is hampered by some debris.
Or there is not enough air flow, meaning the radiator front is clogged by dust and sand or mud.
So the first questions:
When you go at highway speeds, do you see the temperature gauge then gradually go up? Or is the light coming up while the gauge is still below the red zone?
Did you check the radiator is clean and there is no issue with airflow?
