The setup:
PX200
Malossi 210 Sport w/head spacer
Longstroke crank
0.9mm squish
Polinibox
Standard gearing w/24 tooth clutch gear
SI24 carb (drilled out to 2.5mm), standard filter
160/BE3/130MJ, 52/140 idle
Jetting ever-so-slightly rich
Timing at 18 (strobed) degrees
Steps to reproduce:
1. Go out and rip around with this awesome touring setup
2. Start climbing a steep-ish hill in 4th at near-WOT
3. Discover said hill is just a bit too steep (speed drops from 110, to 105, to 100...)
4. Downshift to 3rd and stay at 3/4 throttle
Expected result: the engine gamely pulls the bike up the hill around 7500 RPM
Actual result: the engine makes an unholy rattle that sounds like pinking, and you roll off the throttle, and plod up the hill at 6000 RPM which makes the sound go away.
You don't need a hill to reproduce this -- it just needs riding under load in 4th and then downshifting to 3rd, and keeping it under load.
My first thought it's knock/detonation/pinking. This is the best close-up I could get of the plug and yes, there are some flakes in there, only visible by taking a macro photo.
(The oily ring is likely hanging around from the too-rich state it was in while I was dialling things in.)
So then: why is it so reliably reproducible under those conditions? I've read all I can about detonation and its evil cousin, pre-ignition, and gosh if it doesn't make your head spin. What are the next things to try?
1. Retard the timing by another degree or two?
2. Start messing with the squish?
3. Enrich the MJ?
There's another option, 4, "Get a properly tuneable carb", but I'd like to stick with the SI.
Thanks in advance for any advice!
Cheers,
JVM
