Hi friends, I hope this sees you well. I have been stuck trying to get into the 80 on 8's club and am now finally coming up for air.
I'm cooking the 2 smaller lighting coils & blowing bulbs due to excessive vibration (I think). It probably doesn't help that I overrev to 9k on a 60 year old scoot that shakes, rattles and rolls like a Big Joe Turner song.
My thought is to just switch to full wave and run the TrailTech Regulator/Rectifier with a small 1.2 Ah battery (kick start only). This will give me DC power to be able to run LED's and then thief some power to run a USB or GSF dyno.
The ignition coil is not part of this conversation and we are going to pretend that it does not exist for this discussion.
So watts the problem?
I pulled my stator and found something I didn't expect. Coils 1 & 3 are in parallel to each other and then in series with coils 2 & 4. WickedWeed drew a sweet schematic and it seems to line up with what I am seeing on my stator. Maybe this is how BGM is able to claim "more power" than stock. Here is the link to his MV thread BGM HP 2.5 Stator: Coils parallel. I also noticed that his stator coils are burned out similarly to mine.
I have found a video on Savage Scooters YT where they removed the grounds to the coils and then hooked up a wire to the coil where it did go to ground and called it good. This would give you a floating ground, but still leave coils 1 & 3 in parallel.
Possible Solutions: Coils 2 & 4 need to be replaced no matter what.
1) Replace damage coils with same thing, float ground and keep 1 & 3 in parallel with the rest in series (Savage Scooter solution)
2) Replace damage coils with same thing, float ground and have coils run in series (SLUK Solution)
3) Replace all coils with the same number of wraps per coil, float ground, and run in series
4) Replace all coils with the same number of wraps per coil, float ground, and run 1 & 2 and 3 & 4 in series respectively and then run the 1-2 combo in parallel with the 3-4 combo.
Questions:
-For a P-series (5 wire), how many turns are in the smaller coil? How many for the larger coil? What gauge? (According to Wicked Weed, it is 60 wraps for small and 70 wraps for big but I have not personally verified).
-What is the downside, if any, to running mismatched # of turns in series?
-Could running coils 1 & 3 in parallel be why I see every BGM stator on this forum with blackened coils 2 & 4?
-Does anyone have any idea how the BGM V4.5 DC Stator (8040N) has its coils arranged? I attempted to figure it out via the pics, but couldn't quite get there.
Background:
I suck at posting and maintain a presence here. Scoot as follows: VBA w/ a P187 engine, 7800rpm max power, 9000 overrev. BGM Stator 8025N (3 CDI wires, 1 black & 1 Blue for power) and stock flywheel. All AC w/ TrailTech AC Regulator. I'm using a BGM 9077011 wiring harness & switch and I have verified there is no rubbed wires in the usual places & grounds are attached.
Power requirements:
Max Power needed = 60W, Power needed* at idle = 30W. Breakdown below.
21W - LED Headlight (BA20d)
9W - LED tail/brake/pilot light (BA15S) @ 3w each
15W – Battery Charging
15W - USB
*I am ok with drawing on the battery at idle (1k rpm), because I rarely idle the bike.
Q & A:
What is fullwave, what are you talking about?
https://mastercircuits.blogspot.com/2011/06/half-wave-stator-to-full-wave.html
Do you have to have fullwave to have DC?
You do not, you just don't get the "full power" of the stator on the DC Side.
I want to know more about the science of stators, where should I go?
I would suggest checking out the Stators Demystified thread on AdvRider.
Links:
Scooter Lab UK (SLUK) article for converting stator to fullwave
Savage Scooters DC Conversion of BGM
Scootronics YT explaining the conversion if your coils are in series. This dude is a trouble shooting god.
Thank you for coming to my Ted Talk on why you should just buy a Vape ignition to begin with!!!
