@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
Are the 2 rear view mirrors interchangeable? Was planning to purchase a well priced LEFT side mirror … my bike now has the left side mirror. I'm sure I can swap it to other side to test but want to be sure if they are interchangeable. Anyone know? The mirror I'm looking to purchase has same part number.. like I said it's being sold as a left side… which I have. Mine in photo has a "L".. guessing it's left which leads me to believe they are not interchangeable.
How about you try putting the one you have on the other side?
@jcg avatar
2008 GT200L
@jcg avatar
2008 GT200L
Yes, i mentioned that but again didn't want to do something that was wrong
@jkj-fz6 avatar
@jkj-fz6 avatar
I don't know about a 200L, but some models use left-hand threads on one of the mirrors. That would make them non-interchangeable. I'd first check the threads on the mirrors.
link: Woe is me… snapped mirror off
@madison_sully avatar
In my experience the left-handed thread is on the right stalk. Reason: a hit from the front rotates each mirror in a different direction, and you want the mirror to loosen if possible, not break.
@berto avatar
2018 Liberty 150
@berto avatar
2018 Liberty 150
Aren't the arms bent in a particular direction? I don't see how these could be interchangeable, regardless of threads.
If you don't want to swap your mirror over to verify this, you could also compare left/right part numbers on a parts website
if same thread then you can swivel the head fully around
@abner_bjorn avatar
@abner_bjorn avatar
Nope. Two different part #s.
@greasy125 avatar
@greasy125 avatar
it does not, the mirror mounts for the GT are standard thread
for my 2009 GTS (and I'd guess all bikes pre 2014-ish):
iirc the *mirror* (including thread) is the same but the *rubber gromet* is different for left vs right hence the different part number as when purchasing they come with grommets. grommets are reusable/swapable when replacing mirrors
Yamaha is known for using standard and left hand threads, but there may be others as well.
It fits.
But a right mirror is less than $40. That's not a lot.
@pigletpilot avatar
@pigletpilot avatar
The L on the rear of your left mirror is unlikely to mean left. In Italian it would be S for Sinestre, and the right would be D as in Destre.
And if Sinestre reminds you of perhaps . . . sinister . . . there's a good reason. Left handedness was considered sinister many moons ago. Right handed people now just feel common as against the approximate 10% of the population who are left handed and special. As I saw once, "everyone is born right handed and only the best get over it".
@abner_bjorn avatar
@abner_bjorn avatar
[ Time: 0.0132s ][ Queries: 7 (0.0031s) ][ live ][ 339 ][ ThingOne ]
