@scootermarc69 avatar
Is one preferable to the other?
@psma avatar
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
@psma avatar
Function is so basic I guess they are pretty much the same. But with SIP you have the option to buy the version with reserve alert, if desired. My 2 cents
@chandlerman avatar
Innovator
156 Days Since Last Explosion
Innovator
@chandlerman avatar
Functionally, they seem to be identical.
I just throw one in with an order of other parts from whichever site I happen to be on and couldn't tell you which is which after the fact.
@oopsclunkthud avatar
1:3
I've had issues with the BGM tap not flowing well on reserve on my GS. I'm switching to the second version of the SIP tap but can't report on results.
Scooter speed had both. Went with the sip. The angle of the barb maybe matches the stock one I have. Also had problems with the BGM 1st gen on a large frame in regards to getting airlocked when running onto reserve.
@ray8 avatar
@ray8 avatar
It's a thing. At least it was with the earlier version:
@108 avatar
V range 50s
@108 avatar
V range 50s
I've installed both, SIP 2.0 is a better design. Larger holes and better angle for the hose… you can install a 8mm hose on the SIP, the 6mm will be very tight.
The BGM is a boxed version of a tap made by OMG… it works, but definitely slower flow than the SIP
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
I have a recollection that someone on here documented a case where one of them (don't recall which, too lazy to search) had a tap which had the holes almost completely blocked with flashing when it was DOA and they tore it down.
If folks say go with the SIP, I'm not going to argue--like I said, I've used both successfully in the past and have no complaints about either one, but it sounds like the SIP has a better spec.
@108 avatar
V range 50s
@108 avatar
V range 50s
Black seal= SIP (holes are around 4.8mm)
Red seal = BGM (holes are 3.9mm)
The tank tap nut is the same size, so the SIP is much bigger
Sorry, the green tick doesn't mean anything… it's an old photo sent to a friend telling him the holes have been cleaned…
The sip one arrived from Scooterspeed today! Only ordered it Sunday night! Great service! Looks like the "reserve" has been corrected to be at a useful level. Come with a nice looking lever with 2 different holes for small frame and large frame I assume. Happy with my choice.
I have a sip 2 fast flow, it certainly improved fuel starvation issues i had on my px when my tank got very low on fuel. For a cheap part certainly worth it and ironed out my issues.
[ Time: 0.0135s ][ Queries: 4 (0.0047s) ][ live ][ 343 ][ ThingOne ]
