'66 VLB (Blue Badge) & '17 GTV
I'm changing the gearbox oil soon, and it was recommended that I go with regular 30W non-detergent oil, and I know that is what is in there now. I searched a bit and see that some are using more modern synthetics. My shifting is not great, and I know that can be many things, but what is the current recommendation for gearbox oil?
This is for my '66 VLB 150 Sprint
@geeklion avatar
The Dude
The Dude
@geeklion avatar
Personally I stick with the 30w non detergent, Napa brand
@greasy125 avatar
@greasy125 avatar
are you just changing or are you doing a clutch rebuild at the same time?
if just changing, stay with ND30
if you want to change, wait until you upgrade or rebuild the clutch.
but you're spot on, the shifting could be any number of things and I'd suspect the oil least of all.
Just a drain and fill after the recent rebuild. I'll stick with the 30W. The shifting is really not bad, probably just me getting used to how it feels since it's my 1st twisty-shifty (I just made that up, feel free to use it) Thanks for the responses.
@greasy125 avatar
@greasy125 avatar
the GTV= twisty
the VLB= shifty
don't cross the streams, it would be bad.
@scootermarc69 avatar
greasy125 wrote:
the GTV= twisty
the VLB= shifty
Twisted Shifty
@greasy125 avatar
@greasy125 avatar
in germany, the only rules are that there is no rules.
also, where in the F do they put the fuel for that thing?
Camelback! How long do you give the coolant hose passing through the sheet metal, lol
@greasy125 avatar
@greasy125 avatar
the fuel line right next to exhaust is a nice touch as well.
I'm trying to suss out the rear shock. it might be solid mounted?
[ Time: 0.0139s ][ Queries: 4 (0.0035s) ][ live ][ 343 ][ ThingOne ]
