Px 200
Px 200
I have an issue with a malossi kit that struggles if I try to rev it out in almost any gear. It will rev quite high but then it seems to cut out or be starved if fuel. It's fine once I ease off the throttle. If I ride it like a grandma I would not notice the problem almost ever.
It's a 210 sport kit , sip road 2 , si 24/24 drilled out , fast flow tap. Be9plug
I have changed the ignition cap and lead , swapped the cdi too.
I haven't strobed the timing , I just set it using factory marks.
Would off timing cause this or is it possibly fuel starved when the revs are high?
Thanks for any ideas
@chandlerman avatar
Innovator
400 Days Since Last Explosion
Innovator
@chandlerman avatar
What's your jetting?
Because I'm 90% certain you're too lean on your main jet (at a minimum) and you're lucky you haven't seized it yet.
Px 200
Px 200
130 main , BE3 , and an a 52/120 ,
So you think not enough fuel?
It's been running this setup for quite a while, I think the problems always been there , I just rarely ride it hard
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
130 is probably okay, depending on your Air Corrector. What's your AC? That's going to play a big part.
other option is that you need to drill your float passage to allow more fuel from the float chamber to the main jet stack. That probably needs to happen in any case.
Px 200
Px 200
Air corrector is BE3. I've drilled the hole out from float to main stack.
I'm going to try to do a plug chop when it's in splutter mode. Also going to check for twist or kink in fuel line.
@greasy125 avatar
@greasy125 avatar
sounds like CM is on it with jetting prognosis.
I'd start there and see if that yields the result you're looking for.
@scooterist avatar
@scooterist avatar
I am running 2 Malossi sports 210. Both kit set-ups identical except the exhaust which I like to alternate:
I think that your problem is on the 52-120, change it to 55-160. Your 130 main jet I think is OK (I am running 135). The only time I ran bad is on the bad plagio fuel tap which was very old and it would cut-off the fuel sometimes. I changed to BGM 3030 and fixed the issue.
Px 200
Px 200
Thanks Molto Verboso , I'll get a 55-160 and see how it goes
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
You still haven't told us that your air corrector is.
The atomizer or emulsion tube is the BE-3. The AC is on top of that and is going to be a single number, like 120, 140, 160, etc.
My guys is that it's going to be a 160, which is too lean. You probably need a 140, if not a 120, depending on your intake timing, porting, and port timings.
Jet Eye Master
Jet Eye Master
Make a sound recording while riding at high revs. Probably just the jetting though. Any air filter?
Px 200
Px 200
Aha , I didn't even know that was a separate part until now.
Air corrector is a 160 , I'm trying to find a 140 local to me. I found a 120 so hopefully I'll have both to try by next week.
@chandlerman avatar
Innovator
Innovator
@chandlerman avatar
Now we're talking!
If you have a 120 at hand, put it in and give it a shot. It might be rich in the mid-range and WOT, but that'll at least confirm the diagnosis and show you're heading in the right direction.
@scooterist avatar
@scooterist avatar
Any updates?
Px 200
Px 200
scooterist wrote:
Any updates?
I got a 140 ac and a different idle jet , don't have time to try them out just yet , will know what the do on Sunday
Px 200
Px 200
I tried a larger main jet , tried a 55/160 idle and tried a 140 air corrector. I did them all separately and they all resulted in bogging.
I changed the fuel line and it's running pretty well until I put it on to reserve. I'm thinking it's something to do with the fuel tap when tank is either on reserve or near it.
I will try a smaller main jet just to see what that does.
My 177 was doing this when tank was low until I changed to sip fast flow 2. Does yours do same thing when tank is full?
Px 200
Px 200
Problem solved! The seat was blocking the breather in the filler cap.
It was an aftermarket king n queen one and getting on a bit so it probably had more flex when I sat on it.
I swapped to original seat and runs fine now, even too rich so I dropped a jet size and it's even better.
[ Time: 0.0140s ][ Queries: 3 (0.0074s) ][ live ][ 343 ][ ThingOne ]
