2021 Sprint 150
2021 Sprint 150
Left the house, used the remote to open the seat, all was good.
Got to the store, went to open it again with the remote, starts making a grinding sound coming out near the battery compartment. Had to open it manually.
Any ideas?
Tom
@mayorofnow avatar
2020 GTS 300 HPE ('19 - '26)
@mayorofnow avatar
On the GTS, if you have something under the seat applying upward pressure (e.g. the bucket is totally full), the latch won't electronically open. You have to press on the back of the seat, where a passenger would sit, while you press the unlock button. This counteracts the pressure, and gives the latch space to open.
2019 GTS 300 HPE w Malossi
On my Supertech I took up a habit of punching the rear of the seat when I close it so as to make it lock consistently and open consistently. (Never had to do this with my old GTS)
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Did you put your helmet in the pet carrier while you were in the store? Is your helmet something of a tight fit in there?
2021 Sprint 150
2021 Sprint 150
The thing is, nothing is in the seat compartment.
I just pushed down on the back of the seat, still no joy. Pressing the electronic button causes a grinding sound. Almost like a car with a dead battery.
Called my Vespa dealer, spoke with their Service guy, he said "I have NEVER heard of that." So in it will go I guess. Thing is like, 4 days old. Not good.
@jkj-fz6 avatar
BV400, Primavera 150
@jkj-fz6 avatar
Is the battery weak?
New != Tested...
You become the test pilot of any new vehicle. I bet it's either just the latch position that needs adjusting or an actuating cable has come adrift.
2021 Sprint 150
2021 Sprint 150
No the scooter starts up fine…
@billrush avatar
@billrush avatar
I just walked to my garage to look at my sprint 150. I usually forget to use the key fob button. But either way you hear a mechanical whine coming from near the battery compartment pulling the cable that releases the latch. I'd look for ways to get at that cable if you weren't headed to the dealer with a brand new scooter.
What do you mean when you say you had to open it manually?
2021 Sprint 150
2021 Sprint 150
Open it manually with the lever inside the little storage compartment, as opposed to anything electrical, like the button or the remote key fob.
@johntee avatar
Vespa ET4
@johntee avatar
Vespa ET4
If I was in your position I would take it back to the dealer you bought it from and ask them to fix it . I assume that you have a warranty to cover any problems .
@hells_grampa avatar
2018 GTS
2018 GTS
Mine does that as well. Somebody put some pieces of weather strip in the channel that the seat cushion seats into when the pet carrier is closed. Why they did that is beyond me. The only time it would rattle would be when the bike is running, and with my generous derrière planted on the seat, I doubt it is going to rattle anyway.
@billrush avatar
@billrush avatar
Oceantracks can you give us an update?
[ Time: 0.0109s ][ Queries: 3 (0.0023s) ][ live ][ 343 ][ ThingOne ]
