I have a 1982 Vespa p200e, cdi, with turn signals, no battery.
I found the wiring diagram on scooterhelp
https://www.scooterhelp.com/electrics/wiring/VSX1T.no.battery.pdf
The wiring in the headset is a bit confusing even in the diagram, just over the headlight bulb you see 3 dots in line, a symbol that I'm not sure of the meaning, I thought at first that it meant that 3 wire were connected together at this point, but now I doubt it since elsewhere in the diagram there are not as many wire as they are dots?
But the strangest thing in that connection is that it seem that the grey wire from the right switch would be connected directly to a ground and also connected to the green wire wich come from the regulator wich I tought was providing power?
Any one can help me here, or have a clear photograph of the wiring in the headset, concerning this grey wire from the right switch?
Thanks,
