2008 GT200L
2008 GT200L
Bought this from a private party after checking to see if was compatible…scooter west showed it was… but does it? 2008 GT200
Racing Sixties 300, Cub, Gold Wing, Can Am
It sure should. You might want to loosen up the four screws on the windshield a touch, then make sure the mounting rods are pushed in all the way before tightening them.
It looks right. Having said that, the windscreens for the GT/GTS and for the LX series are different as they mount at a different angle and the size of the headlight enclosure is a bit different.
2022 Liberty 150S-"Meg"-SOLD
Ought to work just fine.
Make sure the expansion bolts are a little loose before you lightly tap them in. They'll make a solid sound when the bolt hits the back of the hole.
A little bit of water on the rubber part will help them slide in all the way. Then tighten until snug.
2008 GT200L
2008 GT200L
It worked out fine!!! Thanks
2006 LX150
2006 LX150
JCG wrote: It worked out fine!!! Thanks I believe I speak for the majority here when I say please post pics!
.... and clean it with care, they scratch really easy.
2008 GT200L
2008 GT200L
I noticed that.. can fine scratches be taken out? Saw a few YouTube videos using polish and cleaners to remove scratches. I can see that the seller tried cleaning mine incorrectly which resulted in of course swirling scratches.. not deep, but not good
Plexus is a good cleaner and plastic polish. With more serious scratches, it is possible to get an assortment of really fine wet or dry sandpaper (800, 1200, 1500, 1800, etc). By working coarse to fine, and then polishing, you can remove most scratching.
