STC is short for 'Seamless Transmission Clutch'. This describes the steady, even clutch engagement that it provides once fitted. This advantage is due to its special, innovative construction. Whereas the frictional operation of most automatic clutch types saps power from the transmission, the REVENO STC clutch set up eliminates this problem. When it rotates the internal roller weights, similar to a variomatic transmission pulley, are pulled away from the centre of the clutch by centrifugal force. This causes the inner clutch plate come into contact with the friction plates and further transmit the motors power. The rpm at which the clutch engages can be adjusted by exchanging the roller weights with those of a different weight.
