I know that it's topic discussed many times…however never understood the below:
is it or not necessary to trim the rear hub 1mm approximately for correct alignment of rear mp3 yourban rim to a vespa gts 300 hpe??
I'm kind of confused…One says yes it does so it can be placed in line with front rim due to different offset with the vespa's 12 inch rims, others say no need…What exactly is the correct for this modification?
