@robbie_11 avatar
PX
@robbie_11 avatar
PX
Ive drilled out my fuel bowl to main stack to the recommended 2.5mm to help prevent fuel starvation.
The problem is Im not sure if ive drilled through far enough?
I cant see the drill when I look down the main stack hole?
When i measure how far I drilled through its around 10mm.
But when I make a close up photo of the drilled hole I still see a small edge at the back of where I have drilled.
Is this expected or do I need to drill more?
Just dont want to drill right through.
Here is a photo.
Cheers Robbie
Jet Eye Master
Jet Eye Master
When it's through you can see the drill bit at the bottom of the stack. Carry on.
@robbie_11 avatar
PX
@robbie_11 avatar
PX
OK Jack..will do…
Thanks…
@psma avatar
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
@psma avatar
Robbie 11 wrote:
OK Jack..will do…
Thanks…
Famous last words ... PUMM!
Just kidding, go with fear, but go...
@sdjohn avatar
Johnny Two Tone
'15 GTS300, '86 PX125EFL, '01 ET4
Johnny Two Tone
@sdjohn avatar
A hand drill set is most useful here - you won't break through the bottom because you will feel the bit when you reach the stack turning free.
Called a pin vise.
@robbie_11 avatar
PX
@robbie_11 avatar
PX
Called a pin vise.
Great idea…
Never thought of that. Could save me buying a new carb 😜..
Thanks for the tip…
@qascooter avatar
@qascooter avatar
And if you're concerned about not seeing the drill bit, stick a smaller drill bit that is smaller than the hole until you see it pop into view. That way you at least know what you're looking for....
@garncarz avatar
@garncarz avatar
It this a recommended procedure for all Dellorto SI carbs?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
You can also put a smaller bit in hole, to get a depth measurement, transfer that to larger bit with a marker etc. Then put a piece of electrical tape as a flag, for a visible depth mark while drilling.
@greasy125 avatar
@greasy125 avatar
not really, it's more for performance oriented builds. it certainly can't hurt, but it's not necessary for a stock build.
[ Time: 0.0119s ][ Queries: 4 (0.0056s) ][ live ][ 343 ][ ThingOne ]
