We all know checking oil is a PITA - and I'm considering the sight glass - but for now, am I the only one that finds it hard even to read the stock dipstick?
2001 GTS Super (white), 2021 GTS Super (yellow), 2013 LX 50, 2009 Genuine Stella 2T, 1986 Honda Helix, 1976 Bianchi Snark moped, 1980 General 5 Star moped
Posts: 937 Location: Powhatan, Virginia |
TheMayor wrote: We all know checking oil is a PITA - and I'm considering the sight glass - but for now, am I the only one that finds it hard even to read the stock dipstick? ⚠️ Last edited by Mopedlar on UTC; edited 2 times
PeterCC wrote: What is so difficult then? |
2019 GTS 300 HPE w Malossi
Posts: 9501 Location: Batmania aka Melbourne, Aus |
Mopedlar wrote: I think when you unscrew and remove the dipstick, it smears the oil level just enough to make it difficult to tell where the actual level is. |
steelbytes wrote: generally i find that only one side smears so I assume the non smeared side is accurate enough |
Mopedlar wrote: I think when you unscrew and remove the dipstick, it smears the oil level just enough to make it difficult to tell where the actual level is. When it is anywhere between min and max it is OK. |
It's a pain in the ass to access and read. I will be doing the site glass at the next oil change.
Posts: 3931 Location: Asbury Park, NJ |
I just put in my order to SIP for the remaining stuff to get Thelonica to serious highway-worthiness-and-such, which includes the Buchsenfuchs (damnit, I still cannot say or write that name with a straight face) sight-glass-equipped oil pan, while shipping charges are still relatively sane. There's also one other little item Buchsenfuchs makes which apparently is only available directly from them, and since their site is entirely in German, I'll need to contact them directly about it: it's essentially a hose/line that replaces the oil cap/dipstick for the HPE, and runs up into the engine compartment, allowing you to add oil by removing the Per Carrier basket, and (presumably) using a small funnel to add oil, rather than getting on your knees to do the job. Between this and the new oil pan (which I'll have he dealer swap in at the bike's first service), keeping tabs on Nica's oil level should be much less of a hassle.
Whatever they actually call this thing, I think it'll do my bike some good.
